Question about SanDisk 2GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter
My Computer say i need to format my micro memeroy stick that i use for my motorola w490 but when i click format it say it can not be formated and that it might be a read only file. How do i format it so i can put music on it.?
  • 110 Answers
Go to My Computer, right-click on the Drive of the Memory Stick, and go to Format.
Posted on Sep 29, 2009
I recently purchased the device listed below and when I ried to use I received a message that it was either not formatted or formatted for a Macintosh. How do I format it for use with my Dell PC?
Your usb stick could be formatted in either 2 ways:
1) If you go into "my computer" or "computer" (depending on if you are using XP or Vista/7) and you see your usb stick on that list, you can right click on it and select "format". You can just accept the defaults it gives you and hit ok and it will format it to be used on your computer. If it doesn't show up in "my computer" then there is another thing you can try:
2) If you right click on "my computer" or "computer" there will be a menu that pops up, select "manage" from this list. Once a new windows opens up, on the right hand side you will see "disk management". Select this. You will now see a new list of all the hard drives/usb drives on your system. You can right click on your usb stick and hit "format" in the same way as 1.
DISCLAIMER: Make sure that you select your usb stick from these lists, and not your computers hard drive. If you accidentally format the hard drive you will lose everything on your computer.
Hope this helps and if you need any more help just leave a comment here and I will get back to you.
Sep 21, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My motorola w490's problem is it cannot read my memory card,it always says that (inserted memory card:unformatted)
The problem is that your card is not formatted well..Try to format it by connecting to a computer either by phone or by card reader..
now right click the memory card drive and select the format option on the tab.
after the completion of format remove it form computer and insert it on your mobile..
now it will detect your memory card..
i request you to kindly rate me on fixya if i am helpful..
Dec 18, 2010 | Motorola Mobility W490 Cellular Phone
"Storage Device Unreadable. Format Now.?"
yes there is a possible solution to your problem....there seems to be a problem with your card....and it doesn`t look like you can get your data back from it ...so you will have to format your memory card....connect your card to a computer through a memory card reader by also using your micro card`s adaptor and then format it from your computer......hope this helps.....please vote ...help us to help you better
Aug 07, 2009 | Motorola Mobility V360 Cellular Phone
Formatting micro sd card
install your Micro into your pc, go to My computer, and right click on the drive it is in. It will have a dropdown, format being one of the options.Click on that, and it will be done. Once you format it, anything you had on it will be gone, so you won't have a n issu with a virus
Jun 21, 2009 | Motorola Mobility RAZR V3i Cellular Phone
W490 wont read memory card
Hi, sykko_one, I have the exact same phone and was experiencing the same problems. After about a year of using my phone and storing music, pictures, videos, etc. on my phone it would suddenly stop working. Sometimes it would work, and sometimes I wouldn't be able to save or read any data on the memory card. What I did to fix it was completely remove the memory card from the phone and used a micro sd Tinpec card reader, picture here. You want the one that supports micro sd. You can find them on ebay or amazon. Then connect your micro sd card to your pc with the adapter and right-click the removable drive (might be drive e: or f:) and choose format. Leave the default options and format the disk. Make sure you've selected the right disk. To verify this you can open the drive and look at the contents, it should have a folder called "moble." Go ahead and format the drive. Then use chkdsk.exe from the command line to check the disk for errors. Syntax will look like "chkdsk f: /f" or "chkdsk e: /f" (depending on the drive letter assigned to your sd card reader.)
If the format and chkdsk do not work. try just deleting all the information from the card and copying some pictures and music files to it. If these copy successfully then I would assume the problem is with the firmware on your phone. Take the phone to a t-Mobile store and see if they can't re-load the firmware. And don't worry about deleting any data from your sd card, it will not affect the phone in any way, it will just delete whatever pictures music files you have stored on the card. So be sure to back those up first before you do anything. Hope this helps. -Rogueelite
May 06, 2009 | Motorola Mobility Razor Behind-the-Head...
Formating my k1m krzr
take micro sd out of krzr..put the micro sd in the adapter (fits in slots on pc / laptops) go to.my computer, find drive, right click,format..take out re-insert to krzr
bye-bye
Feb 28, 2009 | Motorola Mobility KRZR K1m Cellular Phone
M2 memory card needs formated
insert into your computer, Go to my computer and right click on your memory card. go down to format.
Jan 21, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Format a memory stick?
connect the memory stick to the computer. open (my computer) you will find an icon for the stick, right click on the icon then choose format.. a windows will appear, then you can format it normally.
Oct 02, 2008 | SanDisk 4GB Memory Stick Micro M2 Memory...
Memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
Mar 08, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Memory card
connect the card in memory card reader and got to mycomputer-->right click-->manage-->disk management. see weather you memory size is correct or not if its different right click the memory card and delete the partation then create a new partation
i was done this to my san disk memory card
Feb 24, 2008 | Motorola Mobility SLVR L7 Cellular Phone
SanDisk 2GB Memory Stick Micro M2 Memory Card w/Memory Stick PRO Duo Memory Card Adapter Logo
221 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
