Question about Samsung HL-R6167W 61" HDTV
I just install a samsung BP96-00674A color wheel. Everthing reconnected, when turned on I get flashing lamp and tv keep rebooting, on and off. HELP !!!!!
    Novelist:
  • 184 Answers
Can you hear the color wheel spinning up? You may have to open it up again and look at the wheel assy. Make sure it spins freely. If that's not it, check the lamp door switch. If the door is not on properly, it will keep shutting down.
michtech
Posted on Feb 19, 2009
Have a 50 inch hlp506w model samsung projector tv. it had wavy lines through it, and then turned off. it is continuing to try and turn on with the standby/temp and lamp lights flashing. replaced lamp...
Change the tv Ballast board too.This board only job are to help it to ignite the tv projection lamp. This tv also have a colors wheel design into it too.If tv have colors pictures flashes or Black& White flashes within it pictures or tv have grinding noises or humming sounds,than the tv colors wheel it is warp and dead.This tv colors wheel must be replaced,because the colors dis wheel is warn out.
Jul 05, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
The tv hums, you can turn the volum down to zero znd the tv hums to loud
You have a Bad Color Wheel,that is what is causing loud humming sound.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Color Wheel is Located Behind Lamp ,Pull Lamp out and with a Flash Light Look inside you should see Color Wheel. Color wheel spins 9,000 rpms per second
Apr 12, 2011 | Samsung HLS4676S Television
My HLN5065WX will turn on, play for about 1 minute, flash funky colors then go black. Once this happens you can not shut down the TV. You must unplug to turn off.
Bad Color Wheel, its located behind the Lamp Pull Lamp out and use a Flash Light You should be able to see it.
Samsung Parts.com 1-800-627-4368
You can also go to Encompass website and look up your Model#
Oct 27, 2010 | Samsung HLN5065W 50" Rear Projection...
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
HLR6167WAX/XAA samsung tv wont turn on i already replace the lamp and the ballast but i still get the flaashing light
Tv also have a colors wheel.Now u turn the tv on,u hear squiling,motor or whinning noises?Yes,the colors wheel is dead,replaced the colors wheel.The tv will,work agian.
Aug 05, 2010 | Samsung Televison & Video
Dlp TV won't turn on
possible color wheel , or just a lamp. depending on what the noise sounded like. check out some videos on you tube on how to replace color wheel. Not to hard
May 27, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R6167W 61" HDTV Logo
124 people viewed this question
Henry  Thomas
Henry Thomas
