Question about TruTech PLV16190 Television
The remote control will no longer work even when I put new batter
I have a 19'' tv and the remote control has stopped working. I have the same tv in another room and can use that remote for the other tv so I know it is not the tv. Can you help me to repair or reset the remote somehow. I have already tried new batteries. Thank you.I have the same problem with my 19" tv remote not working
  • 3 more comments
  • scottdnewlin Feb 18, 2009
    My remote problem is only with the Trutech PLV31199S1. It is not a universal remote.It came with the TV. Worked for a little while. Changed batteries. Does not work at all now.
  • scottdnewlin Feb 19, 2009
    Tried removing batteries for 30min to reset remoted, didn't work.
    Last response was regarding loose crystal??? Where is this? and possible IR diode burned out??? DOn't know where/how to get to these. Is there any easier solution like maybe a new remote!!
    ordered new remote
    ordered new remote
  • 679 Answers
Http://www.electronicadventure.us/trutech.htm
from looking at the remote, it seems to be a universal type. If you go to the above website and find the code for your TV, it may work once you put the code back in. This is quite common for this type of remote. I had to input my code a couple times a year fom the wife pushing the wrong button. Just look on the site for the code for your set and try it. Then you will know if it needs to be repaired or replaced, good luck
Posted on Feb 19, 2009
  • 3,037 Answers
Hi
If you want to save some money, the following link will give you instructions of where to send it to have it repaired .
http://www.theremotedoctor.com/
Benjamin
  • 6,784 Answers
Hi, this is a problem with a solder break. Im sure the break is isolated around the actual sensor located on the front side of this remote. you will need to disassemble this device and remove the board gently. after the removal of the board, kindly inspect the whole board. check for looseness in the sensor assemble. it will look like a small led light(very small). this will be your trouble spot. also, check the contact point area on the battery side of this board as well. you may have a lose fit here rendering the batteries inoperable.
  • Michael Masters
    Michael Masters Feb 19, 2009
    This remote is repairable.
    Guru:
  • 832 Answers
Hi there! thanks for using fixya.com!
If you have changed the batteries already. Please try to use any universal remote control if its working on that tv.
I suggest, get a new universal remote control and use it to your 2nd tv. and the original remote control that works on your 1st tv, let it be the remote.
but, if you can have your technician to check on it just to make sure that you don't have a problem with your tv.
Regards! Cheers!
  • Dennis Jambalos
    Dennis Jambalos Feb 19, 2009
    i am not sure, but i got more idealistic and practical solution with this remote control. : (
  • 126 Answers
Hello sir
it seems like the internal chip of your remote is dameged. And sorry remote cannot be repaired so i will you to buy anew one
have a nice day
    Genius:
  • 1,226 Answers
It is a remote problem, repairing remote cost you buck (sometime is pretty to repair but you loss some $) try to compare replace it with new remote or repair the remote.
So it is recommended that new remote is possible solution.
melnavz
  • 1,800 Answers
The problem is related to the IR IC on the TV board check if the sensor is defective or the wohole ic on the borad!!
    Brigadier General:
  • 8,619 Answers
Hi!
I think there is some obstruction on the IR Signal catching sensor of your tv and needs to be checked out. Its on the front lower panel of the tv. It catches the signal from the remote.
Check for any thing kept in front of the lower panel.
If no obstruction is there then you need to get that sensor replaced by a tech.
Thanks
Rylee
Posted on Feb 18, 2009
  • Rylee Smith
    Rylee Smith Feb 18, 2009
    Look for the sensor in the picture---
    Top Expert:
  • TruTech Master
  • 77,202 Answers
I have the same tv in another room and can use that remote for the other tv so I know it is not the tv (FROM YOUR POSTING) WHAT DO U MEAN? U HAVE A DEFECTIVE INFRARED RECIEVER IN THE AFFECTED TV.
  • TruTech Master
  • 19,396 Answers
The remote is a no serviceable part, that means that must not be repaired, and that schematics are not provided.
All you can do is spotting at a glance if you see a bad component or a bad solder joint.
The best solution is buying a replacement.
You can buy it on the links below:
TRUTECH PLV31199S1 remote control
Trutech PLV31199S1 Replacement Remote Contro
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Three possible repairs:
  • it may be necessary to clean/scrape the battery terminals of the remote. The idea is to expose fresh metals. In some instances, it may even be necessary to bend/stretch these terminals so that they offer more pressure in contact with the batteries;
  • a common fault in remotes is a loose/detached crystal. This requires opening the remote and locating the crystal and soldering it back into position. In the example remote board image, it would be the blue component normally marked as X1;The remote control will no longer work even when I - 50667c6.jpg
  • the IR diode has burned out. This would be the part that transmit the remote signals to the TV. A continuity tester (DVM/VOM) would be needed to check for forward/reverse. If replacing, pls be reminded that it has a polarity.c6cd380.jpg
Good luck and thank you for using FixYa.
  • 265 Answers
Remove the batteries for 30mins to reset the remote.
please rate
thanks
    Genius:
  • 1,269 Answers
Is this a universal remote? Make sure the remote has the universal capability. It might be just a dedicated remote to your other TV that's why is only works on one TV. Better give it a try again to another TV to check if it's universal or not.
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
Dec 11, 2009 | Samsung Televison & Video
My remote control no longer works, even with new
First, test that the remote is actually working. The easiest way to do this is to point it at a switched on digital camera and look at the camera display. The remote uses infra red light which the human eye cannot see, but digital cameras can. As you press a button on the remote, you should see a glow coming from the remote in the camera display.
If it is working, it is probably a fault in your TV - not a DIY fix so take it to a repair shop.
If it isnt working, you'll need a new remote. A genuine Panasonic replacement will be expensive so you may opt for a universal one. However, universal remotes wont support all the functions the genuine one does.
Your choice !
Nov 02, 2009 | Televison & Video
Remotes not working
If it works on other device but not the TV then it is the TV.
Aug 12, 2009 | Sharp LC-C4655U 46 in. LCD TV
I have a 19" Genesis LCD TV and I need the Remote Control Code
I have a 22" genesis LCD and can not get my Direct tv remote to work?
Jul 08, 2009 | RCA Universal Remote Control
Sometimes the IR receiver bug in the tv goes out.
To clarify. The remote RM1 for TV 1 will not work on TV1, but the remote RM1 works on TV2.
If this is the case, answer is above.
Best Regards,
Charles
Jan 09, 2009 | TruTech PLV16190 Television
Hitachi tv
I have the same problem. I got mine from a friend and my comcast universal remote does not work with it at all. For some reason it does not acknowlege it.
Oct 22, 2007 | Televison & Video
Remote control no longer works
an original remotes available for ya at http://www.remotes.com for 30 bucks + shipping
Apr 23, 2006 | Sylvania 6319CC 19 in. TV/VCR Combo
TruTech PLV16190 Television Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
