Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
Rinnai Energysaver 1004F on indicator light is red (usally green)
My rinnai has been running constantly this winter and the power indicator light is usually green, but lately the light is red. I have tried turning it off, to reset it. The light will be green for a few seconds, then turns red again. I have cleaned the filters and checked the vent and there are not error messages. Should I be worried?
    New Friend:
Turn every
Posted on Jan 16, 2014
  • 1,420 Answers
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Posted on Feb 20, 2009
2 Suggested Answers
  • 466 Answers
SOURCE: my Rinnai 1004F giving me error code 99
This fusible link may be open. Try jumpering the two leads and see if the unit operates. If it does replace the fusible link. Do not operate the unit without the fusible link for an extended period. It is a safety device and is there for a reason. Hope this helps.
Posted on Jan 04, 2014
Testimonial: "Thanks for the info. By the fusible link, did you mean the part F (Fuse) or the thermal fuse (TF) which consists of TF1, TF2 amd TF3?"
What is the average expected lifespan of the Rinnai Energysaver 1004F
http://www.rinnai.com.au/media/4357111/05604_Rinnai_Energysaver_Brochure_WEB.pdf
At the end of the document, notice there is a 10 pro rata warranty on the heat exchanger. The fact that they would offer you any money at all on a failure nine years into domestic use suggests they consider that part rather dependable. I have no access to Mean Times Between Failures on equipment. Such documents vary in calculations as what is considered a critical failure must be defined.
May 31, 2017 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai DV Propain Heater 556F
Sounds like the relay might be going bad and needs to be replaced
Apr 10, 2008 | Rinnai EnergySaver 556 Air Conditioner
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Jul 27, 2010 | Panasonic Heating & Cooling
When heater first turned on light is green then turns red
Yes this is OK. The green light is showing you that you have power. When the light goes red it means that the burner is alight.
Cheers
May 03, 2010 | Rinnai EnergySaver 556 Air Conditioner
Heater shuts off and lights blink
go to rinnai's website and look up the manual for the diagnostic codes. rinnai.us, look under literature/manuals. type in "556". It will tell you how to retreive the error codes.
Oct 17, 2009 | Rinnai EnergySaver 556 Air Conditioner
Where is the pilot light on Rinnai EnergySaver 1001F
If you smell gas in a Rinnai you have a big issue. This heater is what is called a direct vent heater with an electronic ignition so the combustion chamber is sealed and the smell of gas is an indication that you have a gas leak. Please call a professional today.
Oct 13, 2009 | Rinnai Heating & Cooling
No spark to ignite
vacuumed out area behind filter--it works fine now.
Dec 18, 2008 | Rinnai EnergySaver 556 Air Conditioner
Blinking 12 and I have no manual to indicate what that means.
A 12 code indicates a "Flame Failure" check that the gas valve on the right side of the unit is turned on. If you are using propane have you confirmed that the tank has fuel? You may be able to download the owners manual from the Rinnai website.If not you can contact themat 1-800 621-9419.
This is a great heater and the Rinnai people will be helpful. good luck!
Oct 12, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai energysaver 1004F
Sorry friend!
I think this is it.
www.rinnai.us
Feb 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
1,051 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
