Question about Dryers
Timer Continues to run when dryer is shut off
I have a GE "5 cycle automatic heavy duty xl capacity" dryer. I can't find a model number anywhere on the thing. Just within the last few days, I opened the door when I left home (the timer still had about 30 minutes on it), then when I came home, the timer was at 0 minutes. It works fine, but when I turn the timer it counts down even if the dryer is not turned on. It is not a problem right now, but I would like to fix it before it quits completely. A few questions, what could cause this, where can I find the model number, and where could I buy the defective part? Thanks in advance for your replies.
Josh
  • Anonymous Feb 18, 2009
    It did not seem to do that before. I would turn the dryer off by opening the door, come back from running my errands, then start it back up again. The timer did not move before, unless I just always came back before the timer reset.
  • 686 Answers
The timer keeps on going even if you open the door this is normal
Posted on Feb 18, 2009
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
GE Top loader, Heavy Duty, large capacity washer does not advance cycles but stays in one cycle. I have to manually change cycles.
Depending on the exact model number it sounds like you are dealing with a bad timer or bad clock on the timer. There are contact points inside the timer and they burn out. Sometimes the clock goes bad It has plastic gears inside and is non serviceable. The only thing you can do is replace the timer or call a local repair technitian to make sure.
Oct 26, 2010 | GE Washing Machines
I have a Roper electric dryer 5 cycle heavy duty XL capacity model #REX5635EQ2 & it just won't start, any suggestions? I have not had any problems with this dryer before & empty the dryer vent...
It has a bad thermal fuse located on the blower housing . A narrow white piece with 2 wires attached to it . Unplug dryer before replacing .
Jul 19, 2009 | Dryers
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Mar 19, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
GE 5 cycle automatic heavy duty dryer
Turn off the electricity to the dryer.Try spraying the belt with automotive belt dressing inside that goes around the bucket.. If that does not work it is probably the bushing at the back of the dryer. you will have to remove the bucket to grease the bushing.if it is still good. judging by your details it seems good.But it could be dry.Needs lubrication.
Aug 21, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Year of dryer
INSIDE THE DRYER DOOR IS WHERE MOST MODEL NUMBER ARE OR ON THE TOP BACK OF THE DRYER HEAD,THANKS
Jul 23, 2008 | GE Dryers
Dryers Logo
90 people viewed this question
Top Dryers Experts
