I installed Windows 98 onto a brand new system, and it takes it between 5-10 minutes from when I hit the power button, to where it's finally ready for use. It also freezes often for approx. the same amount of time whiile installing or running programs. It will run perfectly when I load it in safe mode & when I put Win95 on it. It's a Pentium III 500mhz, A-Trend ATC-6240 motherboard, and I have tried PC100 RAM from 64MB to 512MB. Anyone know how I can get Win98 to work?
I have removed everything from the network area of the control panel, because I don't have a network card, and the computer won't be used for going onto the internet. (It doesn't have a modem in it)
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
Lizzy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
What should the network settings be set to? (the computer is not presently attached to a network)
Was this helpful?
Yes
No
Solution #3
kioner - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Even with no network attached, do you have a network card installed? It is not the network, but the wrong settings (most common unnecessary bindings) that delays the computer. When the computer poses a "message" to a non existant network, device or anything and waits till the time-out, this is a delay and can be a long delay.
When open the network from control panel, what protocols, adapters, bindings and services you see installed?
If you have not a net card, but only the necessary for internet connection, then you must see: 1. Microsoft family logon 2. Client for Microsoft Networks 3. TCP/IP 4. Dial up adapter.
And nothing more. From TCP/IP properties, you must set "disable wins resolution" -- Dimitris Magarakis
Was this helpful?
Yes
No
Solution #4
Cato - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Most common is the wrong network settings for this problem. -- Dimitris Magarakis
Was this helpful?
Yes
No
Solution #5
Rachel007 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Hi Dimitris
Download a copy of BootLog Analyzer # Let it look for delays. The most cases delays are caused by the loading of network or communications protocols you do not need.
-- Regards, Bert [MS-MVP DTS]
Remove the NS to reply.
Was this helpful?
Yes
No
Popular Solutions for A-Trend ATC 6240 Motherboard
need location of power sw wire and reset swwire on old ms 65-77 v2.1 mb using new mid atx case with...
(More)
need location of power sw wire and reset swwire on old ms 65-77 v2.1 mb using new mid atx case with 4 fans +pw supply fan. Will stay on only if i plug the mid pw connection to afan if i take off l.e.d.s lite up all fans will run then turn off after 7seconds . i also sence a burnt oder i think maybe i have a weak pw supply.
ms-6577 v2.1 motherboard need location of pwsw and reset sw from atx case to board ms-6577 v2.1 this...
(More)
ms-6577 v2.1 motherboard need location of pwsw and reset sw from atx case to board ms-6577 v2.1 this case came with 4 fans plus pw sply. is this too much for this bd . I smell alittle toasty but it all turns on ok if i connect a fith to the middle. not the cpu fan . ihave a 500 watt pw sply.i want to make sure the wires are connected right and that what i smell is just too much so i can disconnect and just get me a newer bd with instructions...thanks. if icould view a pit .would be great..
Will new micro atx boards fit inside of a hp pavilion 4550z case? I am trying to overhaul my old hp...
(More)
Will new micro atx boards fit inside of a hp pavilion 4550z case? I am trying to overhaul my old hp pavilion 4550z with a new os and new motherboard as well as processor. My problem is I am not sure that the micro atx motherboard I plan to get will fit properly in the old hp pavilion 4550z case.
Planned new motherboard: GA-M61PME-S2P
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
