Question about Monster Cable Monster 200 Agu Fused Power Distribution Block
1997 Buick Skylark has dead short in fuse block
We have battery , alternator and starter off car and when you hook meter shows reading thru positive to negative on the fuse block, you take out fuses it doesnt, Can fuse block be bad
  • kirkmiller May 11, 2010
    lights, fuses, LEDs and a couple other devices will ultimately make a fuse block look shorted. Instead of looking for resistance (ohms) I would put the battery back in. Then, if you have a problem you can start at the fuses and follow the voltage to any problems.
  • CDNMoose
    CDNMoose May 11, 2010
    well to me the fuses complete the ciruit so when you put the meter on it it will read a signal. is your meter reading volts or ohms?
  • 24 Answers
Usually not pull the fuses one by one till it stops reading a short. Or since you have them all out put them in one by one until you see the short comeback. Then trace just the things on that circuit
Posted on Mar 04, 2009
1997 Buick Skylark Custom won't start unless I
posible a bad fusible link or ignition switch
Oct 15, 2014 | 1997 Buick Skylark
Turn the key, heard starter solenoid pop, clicking like there wasnt enough power from battery. Replaced battery, turned key, and all the lights on dash went out, unhooked battery checked connection, then...
Either the cable from the battery to the starter is shorted or the starter motor itself has a dead short or the starter relay has a short. As soon as the key is turned, the starter relay is closing and all the power of the battery is heading for the short to ground. That's why the power seems to be lost.
Feb 09, 2011 | 1993 Mitsubishi 3000GT
Turn the key and solenoid clicks
Im almost 100% positive that it is the starter. ive had it happen on 2 different cubs ive owned. you can test it by either jumping the starter with jumper cables(hook positive and neg up on the battery, and ground the neg cable on the engine, somewhere mettal, not on the starter!, then tap the positive on the nut with the wire hooked to it, its the only wire on the starter.) if it doesnt spin over when the jumper touches, its a bad starter. i dont want to insult you either, but, it could be the battery is going dead, or shorted out. if you have a voltage meter, check and see if it has 12-15volts, and just because its showing 12-15 v, it still could be shorted. leave the meter hooked up when u get your reading and jump the key, if it goes to 0 or under 5volts, its a shorted battery. well, sorry to write you a novel, but, just trying to be helpful, not sure of ure skill level. hope this helps, and good luck. remember, dont give up hope, eventually you will figure it out! -Brian-
Oct 25, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Car keeps going dead overnight. we have checked the alternator and it is good, we just can't figure out what's wrong with it
You have a draw,something is pulling the battery down when the car is not in use,unplug the alternator,and let the car set over night to see if the battery stays up,make sure the light in the trunk,inside,and hood,are not left on,if the vehicle will start up the next day,then the alternator is bad.
Jul 27, 2010 | 1997 Dodge Intrepid
During battery installation , my father shorted out the terminals
Check the ignition switch located on the steering column under the dash.
Jun 23, 2010 | 1997 Buick Skylark
Why my battery keep dieing
Take the battery in at any auto parts store and have it load tested. They will tell you if its a good battery or not. If not get a new one and then test the altenator with a volt meter. If no access to a volt meter take the altenator in and have that tested. If you do have one start the engine and run the probes from the volt meter this way. The positive probe to the negative terminal of the battery and the negative probe to the positive side of the battery. If a reading of voltage shows the diode inside the altenator is at fault. If the reading displays the OL feature on the display the diode is good. Now switch the probes to red on red and black on black and see if it shows 13.5 volts. If it is less than that voltage the altenator is not producing a good charge to the battery so it will need to be replaced too
Apr 04, 2010 | 1997 Buick Skylark
I have a startin issue. At 1st I thought it was a bettery problem, But the battery is fully charged and test as good. When I turn on the ignition to start it does nothing. No lites on the dash, no fuel...
Hello john_harr: My name is Roger and I can give you some things to look at. First make sure the cables are clean at the battery. This being a Buick follow the red positive wire from the battery towards the junction block make sure all connections are tight.Also make sure the connections are ok at the fuse box under the hood.It might be helpful to check continuity of the battery cables. Do this with a volt/ohm meter. current should pass through end to end. Can also be checked with a test light.The battery cables have been known to corroded off inside the insulation of the cable. I would also check all fusible links. They will be over at the junction block. Tug on the wires gently. If the pull apart then it is burnt out and will need to be replaced.
Should you need further help please just ask. Please rate the quality of your answer as this way we know your answer helped. Thank You for using Fix Ya. Roger
Aug 07, 2009 | 1996 Buick Skylark
Monster Cable Monster 200 Agu Fused Power Distribution Block  Logo
Top Monster Cable Car Audio & Video Experts
xxxxxx xxx
Are you a Monster Cable Car Audio and Video Expert? Answer questions, earn points and help others
