Firgidaire washer gltf2070dso displays an f06 fault code and will not clear or unlock key pad washer frozen
  • Anonymous Feb 18, 2009
    My frididaire washer also displays the same code f06 and will n ot starty.
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
My Whirlpool Duet is showing error codes f06 and e02 and wont unlock door or run cycle, what can I do?
Janice,
Here is a link to a website that gives the F06 code, but I cannot find the other code.
http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.
Scroll down towards the bottom to find the Duet fault codes.
Jul 28, 2015 | Whirlpool WFW94HEX Duet 5.0 cu. ft. Front...
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
Error Code 01 F06
Your fault is mentioned here.
An F06 fault code in a Whirlpool Duet washer (the Kenmore HE3/4t's are also made by Whirlpool) usually means a motor-related problem. It usually pops up when the drum won't rotate at all or only very sluggishly. Here's the excerpt from the Whirlpool Duet Service Manual on this:
http://fixitnow.com/wp/2008/10/28/whirlpool-duet-washer-with-an-f06-fault-code/
May 10, 2015 | Maytag Dryers
How do you fix a fault F06 on a Whirlpool front loader washing machine
The "F06" fault code indicates a drive motor tachometer error. This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes. Possible Causes/Procedure: Unplug washer or disconnect the power supply. Check the wire harness connections between the motor and motor control unit and the harness connections between the motor control unit (MCU) and the Central Control Unit (CCU). Based on your symptom and details, the intermittent (F06) error code is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling the repair person back out to re-diagnose the failure. by Joey S MARCH 1ST, 2010 ' Be the first to comment
Jun 14, 2014 | Hotpoint Ultima WF860 Front Load Washer
Maytag Maxima E05 & F06 error codes on washer
My F06 E05 error returns within a moment of clearing all errors. My Maxima has no tach line from the M to the MCU. MCU commo fault is a different error. So does anyone except Maytag really know what this error is? And Maytag only wants to send a service guy to bleed some money from you.
Oct 21, 2013 | Maytag Washing Machines
Whirlpool duet front load washer, F06 error
FROM WHAT I CAN FIND OUT YOU HAVE A DRIVE MOTOR PROBLEM,
IF YOU TYPE IN YOUR SEARCH BOX (WHIRLPOOL FAULT CODE F06) there are several several sites that tell you how to fix it
Nov 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
APC BR1500LCD Fault F01
This is a printout of the fault codes
System Fault indicator is on and all other
front panel indicators are flashing.
Internal UPS fault. One of nine Internal UPS Fault Messages is displayed:
F01 - On-Battery Overload F06 - Relay Welding
F02 - On-Battery Output Short F07 - Temperature
F03 - On-Battery XCap Overload F08 - Fan Fault
F04 - Clamp Short F09 - Internal Fault
F05 - Charger Fault
Nov 23, 2009 | APC BR1500LCD UPS System
Whirlpool AWM8143 sixth sense
Try replacing the brushes this may solve the problem
Jul 03, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
