Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Replaced the lamp, still wont come on.
I'm trying to narrow down the problem before I tear the tv apart. The timer light blinks green for about half a minute, then I can turn it on and hear sound out the speakers, but the lamp never turns on. I think maybe a power surge fried something, but I do hear the fan coming on. Is there maybe a fuse that's replaceable?
  • yankeessuck5 Feb 19, 2009
    tv turns on but no picture and green light keeps flashing.
    President:
  • Mitsubishi Master
  • 1,779 Answers
1- Did you make sure you have the lamp door on correctly, there's a safety switch that activates and wont let the lamp light for your protection.
2- Put your ear close to the lamp door and listen for a slight hum as soon as you turn it on, it will go in cycles. If you don't, it's going to be the ballast module or the color wheel, both these have to be working to let the lamp light. I suggest you call a service center after that, that's the best thing.
Posted on Feb 18, 2009
I replaced the lamp in my Mitsubishi WD 52628 and the tv will still not come on and the lamp light still blinks
"Initialize" a "factory reset". Power on the tv, on the original remote, enter "MENU 1,2,3 ENTER". This will get you to the factory reset window. Initialize the default reset and you are fixed. Try this before ditching the set or tearing it apart. Good luck and post your results for everyone here with the blinking green timer light issue. Thanks.
Apr 25, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
The tv wont power on and the green timer light continuously blinks. I have unplugged the the tv and also hit the reset button.
...OK to begin troubleshooting this. Unplug the set and leave for 1 min then plug up and leave for 2 min push the power button and let light blink for 2 min.... now push and hold at the same time the MENU and DEVICE buton st the same time. this is the self diagnoses feature ... the lights should link then pause then blink again... this 2 digit code will help narrow it down. Also have you check the lamp yet?
Oct 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
5 yrs old, blinking green then red, replaced lamp 4 months ago
You very well could have problem with the Ballast board that powers Lamp or your Lamp Fan maybe defective and if you need orinagnal hand unit for set Call Encompass Parts Distrubtion or Go to their website type in Model number they will list Parts /Prices for your model.
1-800-638-3328 Mats Electronics also sells handunits .To reset timer
Hold VOL- on front of TV and Menu on hand unit at same time for 5secs
if this does not work try it in reverse Hold Menu down on TV and Vol- on hand unit. Check your Lamp Fan see if it quits running while turning set on,if it starts and stops it is defective, other wise Follow wires that Lamp plugs into it will connect to Ballast board that powers Lamp CK it Problem M/B Ballast Board.
Feb 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | Mitsubishi WD-62526 Projection TV
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green Timer lights blinks for about 10 sec. Then Lamp light, then nothing
Definitely sounds like a power supply problem. Check with your local TV repair/service center about getting it repaired or replaced.
Dec 19, 2007 | Mitsubishi WD62627 62" HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
