Question about Sharp Microwave Ovens
Heating element comes on to high by it's self when no buttons have been touched. I had just finished cooking a cassorole. I closed the door and sat down to eat,when after 5 minutes had passed the exhaust fan came on.When I went to see what was going on,I found the heating element glowing bright red. I then pushed the off button to make sure it was off.I left the door opened for a long time to cool the inside off. Then I just closed the door and went and sat down.After about ten minutes the fan came on again.It had done the same thing again.The element was glowing red hot to the point that it was deforming the stainless metal of the inside cavity. Potentially causing a fire if let unattended.The model # is worn off on inside of door jamb. Any help please?
  • 52 Answers
I am sorry but the relay that controls the heating element has become faulty, if you or someone you know can change it then just follow the heater lead to the relay and replace
Posted on Feb 21, 2009
Samsung microwave turns on when open door
The switch assembly is somehow staying "closed" satisfying the interlock and enabling it to run.
Disassemble the unit, beware specially of the high voltage capacitor, if you aren't comfortable or competent, buy a new microwave. If you are mechanically inclined, disassemble the unit until the switch assembly is accessible; it will have the door latch attached to it.
The switch is either broken or something? exogenous is keeping it closed. It may have come loose due to the door slamming?.
It's a simple fix. I am certainl you will be successful.
May 04, 2017 | Samsung Microwave Ovens
Our microwave is a GE Spacemaker, Model # JVM1630WB004, mfg. in Mar, 2001. Just today it suddenly decided not to function other than the light in the oven coming on when activated, etc. It does not cook...
If your microwave oven doesn't seem to work at all, check these:
Fuses
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Oct 27, 2008 | GE Microwave Ovens
Stopped cooking
This is technical!!! Don't know how handy you are but the biggest reason for microwave failure is a diode (HV) between ground and the lead to the magnatron. usually mounted low down low on the right inside of the unit. Also, there are about three microswitches in the door closing latches to make sure the door is properly closed. Sometimes they come loose or fracture the mount. then of course there is the Magnatron its self. I save them from old units. They are different wattages but physically the same and simple to change. Good luck.
Jan 30, 2018 | Advent Mw912bwdk Black Built-in Microwave...
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
Mine is a similar problem - light and fan BOTH stay on when the cooking/heating finishes! The door remains closed and the food/beverage cooks. However, when it's finished the light remains on and the
There are a number of interlock switches that the oven door activates when closed, sometimes one becomes defective causing the main fuse to blow in the microwave or continue to run when time is up.
Nov 11, 2011 | Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
Self start when door closes
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
Jul 23, 2007 | GE JVM1460SA Microwave Oven
Microwave Ovens Logo
73 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
