Question about Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)
Rinnai gas water heater wont heat the water hot enough even though we have turned the thermostat up to 185.
  • 332 Answers
Your temp control is bad and you will have to have a tech to service the unit, contact rinnai and they will give you info on a quilified repair person,, not just any one should be allowed to work on it,, depending on the age it may still be under warranty,, they come with 5 year parts 1 year labor 12 years on heat exchanger this is on all rinnai units
Posted on Jun 29, 2009
  • gary miller
    gary miller Jul 13, 2009
    are you talking about full water pressure or just like a trickle,, If it is at full pressure you may have to have the circuit board checked to make sure that the thermostat is working properly,, have you had the system flushed out lately,, scales will build up and then you won't get the water hot beings it is heateing the dirt insted of the water, but i would have the thermostat checked first
Rinnai 24e
You need to check the water pressure and flow through the unit. It sounds like you dont have enough flow so it is shutting off.
Jan 29, 2014 | Water Heaters
I have a rinnai R53 natural gas tankless water heater. we are having a very difficult time finding someone who knows how to work on these. Our problems include: having to rely on turning on one trusty...
The issue is the flow sensor, if the faucets are restricted (like showers heads) then there is not enough flow to trip the sensor. This could also be related to pipe size and water pressure.
Mar 31, 2017 | Rinnai Desa Vent-Free Infrared Gas Heater:...
When in the shower, the heat fluctuates from hot to lukewarm over a 10 second cycle. The water will not stay at a constant temperature.
this is usually a problem with all tankless water heaters.
the solution is to install a small buffer tank (5 or 10 gallon electric water heater) after the Rinnai. this will give the water something to mix in. it will solve your problem.
did you make sure to use a 3/4" gas line to the unit. not just 3/4" at the unit itself. sometimes when there is not enough gas, the unit will act funny and cycle from hot to warm or even cold. Make sure you check the gas line size, its very important.
Aug 10, 2010 | Rinnai Water Heaters
Rinnai R50LSi water heater- Water doesn't heat.
Flow meters can get jammed by silt or debrise. The only way that I know to check this problem it to remove & inspect the part and that takes alot of training if you have a Rinnai (not recommended for the beginner).
One thing you could check is the inlet screen. Turn off the water and power to the unit and drain down. The screen in the black plastic circle on the inlet fitting under the unit. Unscrew this and check how much grit it has collected. Clean off, replace, turn water back on, open a hot faucet to get the air out then turn the power back on. This sometimes improves the flow enough to solve the problem.
Apr 16, 2010 | Rinnai Water Heaters
Can't get hot water heater to work - Rinnai Infinity 18
If you can get to the gas valve make sure it is in the on position and not in pilot or off. Does it sound like
a spark ignition system? Even though you say the gas valve is on, by code thered should be a gas shutoff valve located within site of the unit. Follow the
gas pipe until you find such a valve and make sure its on
Feb 07, 2010 | Rinnai Vent Free Gas Heater/
Have some heat in 2000 ford expidition but not
have your heater core pressure checked. it maybe clooged even though you had system flushed. additionally did you buy the correct thermostat? the computer is a sensitive thing and alot of other components are activated because of the temperature. the opening temp is 188-195 degrees. so you should have bought the 185 degree thermostat. i had same problem and bought the higher temp thermostat. i couldn't believe that such a small change would make a big difference. good luck.
Jan 26, 2010 | 2000 Ford Expedition
I need the manual for a Rinnai Infinity 26 hot water system
you can get it off the rinnai web site they have a spot on there to get the internet manuel,, but from what you are saying you may need to adjust the thermostat, or the temp, remember even though you will have endless hot water it still takes the smae amount of timed for the hot water to get to your faucet,, not only that make sure your shower heads aren't holding back to much water pressure, if you don't have enough water going thru the unit it will not stay lit, if will come on and go off, judt to dstisfy the unit,, make sure the filter is clear, on the cold side there is a cap screw if you take it off there is a screen in side you just pull it out and clean it and reinstal it,,
Jun 25, 2009 | Rinnai Digital Remote Water Heater Control...
INSTANT HOT WATER ISN'T HOT ENOUGH.
http://homeappliance.manualsonline.com/manuals/mfg/rinnai_corp/reuva3237ffu.html
http://www.houseneeds.com/shop/HeatingProducts/RoomHeaters/rinnai/rinnaimanuals.asp
Here are two links to get the manual for your unit. Since I don't have the model number for your unit, you can find this in one of the two links. If you have the manual, you will know if you are skipping a step or not. If you have done everything, then I would call Rinnai to find an authorized tech for your appliance. Hope this helps.
Mar 20, 2009 | Rinnai Digital Remote Water Heater Control...
No hot water - Rinnai tankless hot water heater
sounds like the water line is frozen before it gets to heater. You can take a blow dryer and try to thaw the line.You should be able to hook up a hose on the hot side of water heater. turn valve off so it wont flow into house.You can turn on hot water valve on in kitchen but you will have to thaw cold and hot line. Make sure you know where water shut off is to the house just in case a line breaks.
Jan 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai R53 Natural Gas Tankless Water Heaters
It sounds like the Rinnai units are working correctly but you've got some plumbing problems.  Any tankless heater has a minimum water flow required to keep the burners going.  If the burners were going with very little water flowing through them to carry the heat away, the heat exchanger could overheat and fail.  The solution is generally to the electronic controls to set the desired temperature and then just use hot water.  Once you start mixing cold water in, you actually reduce the flow of hot water and the burners turn off.  If you are right near the cut off point, the burners will cycle on and off resulting in those very annoying hot-cold-hot-cold showers.
The fact that you've got those very loud noises indicates some other sort of plumbing problem.  Hooking up two tankless units in series is much more complicated. In heavy draw situations, the second unit is asked to finish heating the water up to temperature when the first unit couldn't quite get it there. Now you're putting hot water into a heater and heating it more.  You have a lot more issues with fluctuating temperatures and pressures within the pipes which could conceivable cause these horrible noises.  Everything's got to be set up right to for things to function properly and it's easy to get something wrong.
From your description, it sounds like a better solution would have been to mount the two heaters in different places. e.g. One in the basement to serve basement and first floor faucets.  The other on the second or third floor to serve those two floors.  Since these units are direct vent (don't use inside air), they can even be mounted in a closed closet as long as the vent can get to the outside.  With this setup you avoid the complexities of a series installation and you also have a much shorter wait time (and therefore less waste) for the fixtures on the upper floors.
Mar 26, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
240 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
