Question about Whirlpool LSR8233J
Wont spin washer wont spin but the motor runs
  • Whirlpool Master
  • 528 Answers
The gear between the motor to the gear unit broken its like triangle shape with 3 pins and rubber disk.
you need to take water pump out then the motor and you will see it. you can buy new one in sears part and put it all back. good luck
Posted on Jan 02, 2010
  • 426 Answers
I had this same problem once and it was pretty simple, I removed the agitator asembly, not 100% sure on your model. and there is a cupling between the moror and the agitotor. the guy at the appliance store saidit was a sacraficial part that brakes when a large load is put on the motor to protect it. usually like a 13.00 piece
Posted on Aug 27, 2009
Washer will spin out!! but it wont wash!!!!
May be a transmission problem if the motor does run while trying to agitate. If not it may be a motor problem as they do run in both directions, one for spinning, draining and one for washing.
Dec 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine wont spin in spin cycle ,makes spinning sound just wont spin
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 01, 2010 | Washing Machines
Washer won't spin
You need to check this part of you machine:
Test the lid switch
Test the timer control
Test the centrifugal switch
Test the water level switch
Inspect the motor coupler
Inspect the drive belt(belt drive only)
Inspect under the washer for soot (clutch)
Test the motor
Inspect the pulley
Test the transmission
Check this parts this are the some cause to not spinning.
Dec 10, 2009 | Maytag Neptune Washer
Washer wont spin
It is your cluch on your motor. Your cluch what holds your transmission in place while spinning.
Nov 18, 2009 | Frigidaire FWS833A Top Load Washer
My washer wont spin it shows an error e 13.
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Thank you for contacting Fixya.com
Aug 19, 2009 | Bosch Nexxt 300 Series WFMC2201UC
I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer wont work
If the motor is running but no agitation or spin is happening, then most likely the coupling between motor and gearbox has gone- look for black sooty deposits under your washer as proof. There may also be one or more pieces of white plastic. This coupling usually goes if the washer is overloaded regularly.
Dec 29, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer doesnt spin
ck the coupling between motor and gearcase it is probably broke and won't drive the transmission
Nov 08, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
60 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
