Dumb question, but what is the +RW and -RW? What do they mean?
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
Lizzy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Just remember that with DVD's, faster is not always better. I often find that if I have trouble with a disc burned ts 4x, trying it at a lower speed often helps, but this is dependant on the media you use. I'd steer well clear of the budget unbranded discs and go for more expensive brands... Ritek media using their G04 dye is probably one of the best these days so check before you buy...
Lorne
Was this helpful?
Yes
No
Solution #3
jessie25 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I don't have an 8x but I just got my first DVD burner last week... the Pioneer A06 recommended by Alvin and it's superb. Dual format + and have used Memorex DVD-Rs, have made 5 so far... and not a coaster in sight.
Just like CDs, R is writeable once only and RW rewritable.
If you're ever going to play your DVDs in a standalone player, check at # to check what your particular standalone supports. Most support both formats, but if you're not going for a dual format burner, you want to enure as much compatibility as possible.
Cari #
Was this helpful?
Yes
No
Solution #4
kioner - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I just installed this one and it works great. I found it at geek.com. DW800A-N -- BenQ 8x4x12 DVD+RW 24x10x40 CDRW IDE Drive w/SW I burned a CD and a DVD last night and they work perfect.
T
Was this helpful?
Yes
No
Solution #5
Rank: Apprentice
Rating: 0%, 0 votes
Hello
Go with either sony or pioneer both drives are rated very high and both are great products with a good price.
Sony DRU510A #
PRICE $179.99
Pioneer DVR-A06U #
Alvin
Was this helpful?
Yes
No
Solution #6
Riddle - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Most newer DVD Writers are now coming out with the both standards (+RW, -RW). I would not attempt to buy any older, single standard writers nowdays.
As far as which model, HP seems to have a bad rep with CD Writers so I would lean towards the Plextor.
I recently bought DVD-R blank disks to burn a dvd on , after going thru hours of finding a program...
(More)
I recently bought DVD-R blank disks to burn a dvd on , after going thru hours of finding a program that would change my file into a dvd file ... I get the message that my disk is full when its not ! I found a firmware , i tried installing it & it didnt work ... heres the information i get in Imgburn: Optiarc DVD RW AD-7560S SH03 (ATA) Current Profile: DVD-R Disc Information: Status: Incomplete Erasable: No Sessions: 2 Sectors: 14,912 Size: 30,539,776 bytes Time: 03:20:62 (MM:SS:FF) Supported Write Speeds: 2x, 4x, 6x, 8x TOC Information: Session 1... (LBA: 0) -> Track 01 (Mode 1, LBA: 0 - 14911) -> LeadOut (LBA: 14912) Pre-recorded Information: Manufacturer ID: CMC MAG. AM3 Recording Management Area Information: Optiarc DVD RW A D-7560S DVD RW AD-7560S Physical Format Information (Last Recorded): Book Type: DVD-R Part Version: 5 Disc Size: 120mm Maximum Read Rate: Not Specified Number of Layers: 1 Track Path: Parallel Track Path (PTP) Linear Density: 0.267 um/bit Track Density: 0.74 um/track First Physical Sector of Data Area: 196,608 Last Physical Sector of Data Area: 211,519 Last Physical Sector in Layer 0: 0 Performance (Write Speeds): Descriptor 1... -> B0: 0x00, B1: 0x00, B2: 0x00, B3: 0x00 -> EL: 2297887 (0x0023101F) -> RS: 11,080 KB/s (8x) - WS: 2,770 KB/s (2x) Descriptor 2... -> B0: 0x00, B1: 0x00, B2: 0x00, B3: 0x00 -> EL: 2297887 (0x0023101F) -> RS: 11,080 KB/s (8x) - WS: 5,540 KB/s (4x) Descriptor 3... -> B0: 0x00, B1: 0x00, B2: 0x00, B3: 0x00 -> EL: 2297887 (0x0023101F) -> RS: 11,080 KB/s (8x) - WS: 8,310 KB/s (6x) Descriptor 4... -> B0: 0x00, B1: 0x00, B2: 0x00, B3: 0x00 -> EL: 2297887 (0x0023101F) -> RS: 11,080 KB/s (8x) - WS: 11,080 KB/s (8x) PLEASE HELP ! I NEED TO GET THE DVD's BURNED BEFORE XMAS EVE , I KNOW IM ASKING FOR ALOTT ! BUT I REALLY NEED IT DONE , ITS KINDA A PRESENT (: PLEASE I KNOW MY DRIVE WORKS & THESE DVD'S ARE EMPTY & THE GUY SAID THEY WILL WORK ON ANY OF THE DRIVE. IF you need it , i have a compaq , but i have alot of program thats are HP ... so it might also run HP things (: Any other info you need feel free to email me at : yourasillygoose@hotmail.com PLEASE I REALLY NEED THE HELP !!!
