Question about Emerson MW8102SS 1100 Watts Microwave Oven
Were can i get a door latch for a mw8111ss - Emerson MW8102SS 1100 Watts Microwave Oven
  • 10,865 Answers
Www.expertappliance.com/microwave.html
this is the company i use for microwave parts. love em.
Posted on Feb 18, 2009
Viking Microwave door latch
Try pushing in on the door while pressing the door release latch;
Also, try pushing the door latch and reach under the front edge of the door and slightly pull as the latch is depressed.
Third option is use a suction cup, maybe from a GPS device on the glass portion of the door, pulling on it while you depress the door latch....let me know any problems or if I can help anymore.
Jul 27, 2014 | Viking VMOC205 Convection/Microwave Oven
My Emerson MW8111SS microwave just quit. Is there a fuse that may be the problem?
Unplug first and remove top,Yes! the fuse is located in the right side of the microwave oven, follow wires from the keypad to the main circuit board, look for a silver rectangular capacitor and discharge voltage across the two points, there should a small fuse clipped in, pop it out and replace with the same current rating, keep in mind the fuse sometimes go's if one or more of the door switches is defective. Remember there are lethal voltages present when powered.
Mar 11, 2012 | Emerson Microwave Ovens
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
My Kitchenaid khms155lss-2 has a problem latching completely. Once finally latched the microwave would start and then stop during the cooking time because the door became unlatched. I have to stand by the...
Ok.Agreed,latch is not cracked or worn out.But check the grip of latch.Open the door.The hold the latch in your hand and see,if its loose or tight.It should be tight.Press the latch towards down and move it left/right slowly --- slowly.And inspect the latch.It will move,there will be a moment but the position of the latch in the door frame should be tight.If you feel that latch is got very loose,then the door frame needs to be disassembled and latch assembly has to be repositioned and fitted.In most of the cases this latch breaks/cracks and it needs replacement.But in your case,its different,you mentioned that if you keep your oven door pressed then latch remains closed..So if latch is broken/cracked it will not get closed properly.So as per that i think,you will have to check the opposite side of the door frame,where this latch gets into.On that side,there is a interlock type part.Which holds this latch.That part is operated by spring.If in-case that interlock type part or the spring,any of this is got loose then latch will get released after few minutes.--------------- But first as regular troubleshooting,you inspect the latch.Do you feel its loose or getting very easily moved,then open the door frame and check the latch.----------- For that you will required door disassembly diagram:--- Click the link,see part number 3 is door latch.-------- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0505176-00002.png -------------- If the latch is properly positioned and intact then ,you will need to disassemble the opposite side cabinet to check the internal part,which hold the latch.For that you will require complete disassembly:---Click this link for complete disassembly:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS2/0593/0123370?pathTaken=&prst=0&shdMod=KHMS155LSS2 -------------- The door latch itself or other parts holding the door latch,none of the part is costly then $10.The cost of part is under $10.---------It just require you to figure out,either is cracked /broken part or just loose misaligned part.-------- This will help.Thanks.Helpmech.
Feb 10, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Frigidaire wall bake oven (door opens with hinges on left) won't unlock after cleaning. Turned current off and back on with no results. Fan runs as in cleaning cycle, but door won't open.
If after self cleaning cycle the over door is not getting open.Then in some cases the door latch gets locked and this latch stops functioning so the door does not get open.In this case the front door assembly has to be disassembled and the door latch,it has to be manually triggered/pushed by a screw driver or any such object.So the door latch releases the door to get open.Then refit the parts and check,if the door latch is not functioning as it should be.Then the door latch assembly has to be replaced.After self cleaning,many a times the door latches gets overheated and its connections gets short internally.This is noticed by many other users too.In some cases door latch just gets blocked and triggering it with screw driver,makes it function properly.So disassemble the door and see the condition of door latch.This will help you to decide whether its just locked or got faulty.------------If its got faulty and you require door latch part,then you can get it from the online sites like www.repairclinic.com or from searspartsdirect site.
---------------- This should help.Thanks.Helpmech.
Dec 24, 2010 | Microwave Ovens
I need to find an owner's manual for an emerson microwave oven model # mw8111ss Thanks Ruby
Link below to download,
http://www.emersonradio.com/owners/MWO%20manual/MW8111SS%20Owner's%20Man
Master link below, if the top one fails look in the blue listings, about 14 down from top.
Aug 21, 2010 | Microwave Ovens
Lost manuel on Emerson MW8111ss Microwave oven need to know wattage.
While that exact model is not listed, the top few listed here may be close enough to help you.
Nov 25, 2008 | Microwave Ovens
Emerson MW8111SS
I have the same model and it just turned off by itself and refuses to come back even with it plugged in the wattage that I have is 1000watts. I thought it was my electrical outlet not working but it works fine with other appliances....any suggestions would be of great help...thanks!
Jan 05, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
95 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
