Question about Sony STR-DE685 Receiver
I have a hum or buzz on AM and FM bands only.
All other inputs are fine, with no buzz or hum. Any ideas?
  • Ed Misanko
    Ed Misanko Mar 25, 2009
    same problem for me also no color with s-video cord output to TV
  • Scott Frye
    Scott Frye May 11, 2010
    Electrical interference from somewhere outside the box.
    Is it next to a motor or transformer or fan?
    Problem Solver:
  • 5 Answers
I had the same problem, but it is not the tuner module! An exchange of capacitor C899(100μF/35V) on the standby board has resolved the problem. Under a dollar from an electrical store and you are all sorted. 10 minute fix for those with a soldering iron.
Posted on Apr 05, 2009
Thanks
My portable Bose speaker has just started to buzz a few times in quick succession, then stop for half an hour or so (whilst not in use). I have unplugged it from mains power and disconnected the iPod but...
This may be caused by external interference.
If you have an AM radio available, turn it on and tune to mid-band (1000kHz for example) and leave it on.
If there is a strong source of static (table saw or other motor-driven AC device) it will show up at the same time as your buzz.
If it does not, try the FM band (~100MHz) and wait for the buzz to occur.
One cannot predict more exactly the nature of the interference.
Feb 21, 2015 | Bose Audio Players & Recorders
Low hum on one radio preset on Beosystem 2500
local interference find another frequency for classic fm there are lots
Jul 21, 2013 | Bang and Olufsen Audio Players & Recorders
Surround sound doesnt work. When i switch the surround on there is a buzzing/ hum from the speakers. The sub has a hum in analog mode. I try to switch to theater, club, church etc. And still a hum was...
Back up, open the manual and set it up with test tones to verify the hardware before trying anything else. Then onboard FM. Then external sources (according to their manuals).
Hum/buzz solutions are common on the internet. Do some web searching for "audio system hum" to find somethign that matches your symptom.
Sep 01, 2011 | RCA RT2500 System
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
My Tivoli Model One makes a loud screech/buzz noise
I had the same problem and was able to repair it quite easily. Only thing needed is some basic soldering skills.
Problem description:
  • Suddenly a quite loud and disturbing (scratch/screech/buzz) noise appears.
  • Sometimes the noise is gone but it reappears sooner or later.
  • Changing volume or radio band / input (am, fm, aux) does not affect the noise (even on volume turned down all the way).
  • The signal coming out of the Headphones / Rec Out plug is not affected.
Cause:
  • Cold solder joints
Solution:
  • Unplug from mains
  • Remove back panel (the two black screws next to the plugs in the center). The back panel sticks quite firmly, so it might help to remove the front panel first (the 4 screws in the corners) and carefully press out the back panel from the inside. (The other two (silver) screws are used to attach the transformer to the back panel) and need not to be loosened.)
  • On the circuit board at the back panel locate the plug that goes to the speaker (is says "J2"). Check the solder joints. In my case, looking closely, I could see that they're not good anymore.
  • Renew the joints by heating them up and applying some fresh soldering tin. I also renewd the joint from the wire bridge next to the plug. Just check the other solder joints on the board.
In my case afterwards the problem was gone and the device is working properly again.
Apr 03, 2010 | Tivoli Kloss Model One AM/FM Radio
Loud buzzing and getting only AM reception on the FM setting. Any ideas?
Possible that the band knob has slipped on it's shaft or has become out of line or loose. Try pulling the knob off, making not of the position and see if the shaft is loose. Try to get back to me on this.....
Feb 07, 2010 | Tivoli Kloss Model One AM/FM Radio
Constant hum/buzz only when the distortion is turned up. Otherwise works fine. Already checked cables. Please help.
Distortion is a very HIGH gain operation and any hum on the input will be amplified many times.
Check your guitar AND input cable for ANY hum at all at high gain settings on the amp WITHOUT the pedal in line to assure that the source is not before the pedal.
ADDITIONAL cause could be a poor power adapter for the pedal or even a bad filter cap in the pedal.
Nov 02, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Sony HT-DDW740 Tuner Hum
Hi:
On the stanby power supply replace or have replaced C899 with a 100uf 35V capacitor, this capacitor goes bad and produces hum in the supply voltage to the AM FM circuits.
Dec 02, 2008 | Sony HT-DDW740 System
AM Band buzz
This may well be interference from an external source, for anyone that reads this. Firstly, try another location & power point.
Dec 16, 2006 | GE Superadio III AM/FM
Sony STR-DE685 Receiver Logo
365 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
