Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi 53udx10b 53" The focus went crazy tonight and magic focus stops at red then displays a code 3 ?
    President:
  • Hitachi Master
  • 1,779 Answers
Most likely the Convergence Ic's went bad, best solution is to have a service center diagnose the problem. Normally, they charge $200.-300. depending on the parts. A good point is, that particular chassis is easy to repair for the prof.
Posted on Feb 18, 2009
On our set (approx. 9 years old) - the Magic Focus screen keeps appearing - any idea why?
Likely it is appearing because one of the picture tubes (there are 3, red, blue, green) has a focusing voltage that is disproportionate from the others, and is drifting.
I would think that your power supply is beginning to fail, or one of you tubes is beginning to fail.
Aug 31, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Out of focus and the magic focus will not finish and give a 4 on the botton right of the screen
Hitachi tv magic focus will not finish and the picture is out of focus, what part needs to be replaced?
Jan 05, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I have a hitachi ultravision and the blue is off center.
your convergances amps ics have failed and need to be replaced alone with the 2 burnt resistors you will find then run magic focus
Nov 30, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Double image after magic focus with a number 4
Replace Both Of your convergence ICs STK392-110 they are big black IC will have part# on them Call Mats for parts 1-800-628-1118
Sep 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Magic focus will not reset or update.
Hi, your digital convergence unit has failed. you will need to replace this board asap.
Hitachi Part Number: CS00453R
May 23, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I HAVE A HITACHI PROJECTION COLOR TV. MODEL 53UWX10BA 52". I JUST MOVED THE TV BY TRAILER FROM ONE TOWN TO ANOTHER, ABOUT 25 MILES, WHEN I PLUGGED THE TV BACK IN AND HOOKED UP THE CABLES, THE PICTURE WAS...
Replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Jan 27, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Yellow and blue color ruins total picture on 50" tv,can't get rid
lupe0112,
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
My hitachi 53udx10b tv is out of focus.
rojamon,
That #4 error is listed as "overflow," and I got a"ROM overflow" errorwhen I tried to save my adjusted convergence data.I don't know whatthat all means yet, but if I figure out my problem,I'll post backhere. I've read here and elsewhere that the out-of-focusproblem comesfrom bad resistors or amps on the convergence board. Youcan tryservice mode to adjust convergence. Press the Magic Focusbutton, andthen press it again to stop it, and then press the Statusbutton onyour remote. Here's a link to the manual convergence procedure (scroll down).
Dec 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Magic focus
Repair Magic focus or convergence problem? Because MF is the way you auto set your set to converg and focus.
Oct 06, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
161 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
