Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
WURLITZER 2500 RECORD CAROSEL MOTOR & GEARBOX WANTED!
Can any body have me, I have a wurlitzer 2500 that is missing its record magazine motor and gearbox. Has anyone got one for sale, or might know were i could buy one from. Chirs
    Champion:
  • Wurlitzer Expert
  • 211 Answers
Try 'Durfee' in America. Look up jukebox parts. Or try Bill Butterfield also USA.
Dave F.
Posted on Jun 25, 2009
My wurlitzer 1015 cd jukebok carosel continually
There's a little light like a torch bulb light called the "light gate lamp" which you should be able to see shining at 6 oclock on the edge of the record carousel. It is on the lip where the serated toothed edge of the carousel passes through a small upright bracket. If you can't see it shining then that's your problem. Have a look in the original documentation and it shows a diagram how to change it.
Dave.
May 22, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 Jukebox turntable problem
The 3600 has a hub that is supposed to play dinked and undinked records. They had 33rpm and 45 rpm records back then, so to change the record speed the undinked (small hole ) records pushed down the hub flat when it landed on it, which changed the gearing. When a dinked (big hole) record lands on it falls onto the larger part of the hub. So if the hub is down and stuck there that's your problem. After the hub has been pushed flat (because of a small hole record) it is supposed to rise up again when the record is returned to the carousel. Have a look under the turn table and push up the centre rod.
Dec 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
Records (45's) are sporatically not being picked up by the return
This is either caused by a need for adjustment or a lack of lubrication over a period of time. Please email me for my phone number so I can help you over the phone, Rod, tech@wurlitzer-ohio.com.
Jun 09, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Rainbow
(1) TIGHTEN THE ALLEN SCREWS ON GEARS, THAT ARE ON THE CD MOTOR MAGAZINE.
NOT THE GRIPPER MOTOR.
MAKE SURE ALL SCREWS ON EVERY GEAR IS TIGHT.
(2) THERE IS A SMALL LAMP THAT COUNTS THE CD RECORDS AS IT SPINS, IF THE SCREWS ON THE BRACKET THAT HOLD THE COUNTING LAMP IS LOOSE THAT COULD BE YOUR PROBLEM.
DOCTOR FIX
SEYLEVITT@JUNO.COM
SEYMOUR LEVITT owner of IN-HOME JUKEBOX REPAIR
BALLWIN MO
6362273300
Apr 23, 2009 | Wurlitzer Jukebox CD Player
Wurlitzer arm frozen w/ one digit flashing 8 then E w/o top of E
At the far side of the white nylon gears at the base of the gripper arm is a small white 'duck bill' bracket, which clicks a microswitch when the gripper is over the carousel. When it breaks or comes loose it fails to click the microswitch and the arm doesnt stop.
Dave F.
Mar 11, 2009 | Wurlitzer Jukebox CD Player
Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Oct 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series
The microswitch at the base of the gripper arm is what enables the scan motor when the gripper is over the carousel. You will probably find that the small lever on the base of the tone arm is not clicking the microswitch properly.
Dave .
May 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600
email me at philhemmings@hotmail.com so i can send you an attachment for the jukebox that may help you
Wurlitzer 2500 jukebox
You don't give enough information. Is it in the play position? Is it putting the tone arm down on the record?
Mar 26, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 problem
Most likely the main fuse inside the wurlitzer itself - situated screwed into the lower right hand side of the amplifier panel.
Aug 16, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
248 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
phil
Rick
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
