Question about Kenwood Unity System
No component signal
I have an older kenwood unity all in one dvd player. for some reason I am not longer getting a component signal out of the player. composite works fine.
I made sure the cables are ok and that the tv itself will see a component signal.
No idea what the cause would be. Just turned it on and tried to watch a dvd as normal. tried unplugging it, reconnecting the wires, not sure if theres anything else I can try.. thanks.
I have exactly the same problem with an Aspire AD-900. Also no digital coaxial audio. Composite and analog audio are fine. Did you find out the cause?
Posted on Dec 27, 2009
Kenwood kax-38 amp. distorted sound from turnatable if connected to the phono rca plugs, but ok if connected to the CD rca plugs.
The phono sockets for this are at different line levels for that reason. Phone is for the turntable depending on the type. If it is a later model stereo and an older model cheaper turntable, it uses an older type of needle cartridge called ceramic. The signal output of it is higher than the later magnetic cartridges and may need a preamp (radio shack) to match the line level signal, allowing it to clear the distortion. If this scenario were reversed, using an older cheaper stereo with a later, better quality turntable, the opposite would happen. (signal to low) This preamp would amplify the input. I think you need what is called a matcher to lower the input signal instead of the preamp. I've seen these at radioshack. BTW, the CD input doesn't distort as much because a cd player puts out a high signal and the amp is matched to accept it.
Dec 03, 2013 | SR-10 Adpater Cable - Kenwood Twin-Pin...
Changer harness modification
YES THE VOLTAGE IS THE SAME FOR BOTH UNITS, JUST ADAPT THE PINS.
Aug 21, 2008 | Kenwood DDX-6019 Car DVD Player
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Cannot select play movie with dvd in
if im not mistaken that unit is equipped with "touch screen"... the only problem is on the older kenwoods you did need the remote to navigate the dvd... have you tried other dvds?
May 02, 2010 | Kenwood KVT-815 - 7" DVD/MP3/WMA Rcvr Car...
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
Kenwood DNX8120 can't acquire satellite signals
Check your antenna for a kink. Honestly I have seen the gps antennas on all indashs go bad very easily. Just check that make sure your good. If not you can try resetting the unit with the little reset button on the face.
Apr 07, 2009 | Kenwood DNX8120 DVD Navigation Receiver...
I get a "no signal" message when using HTMI or Component cables
on the remote, press "progessive" until you get a signal through hdmi to your tv
Jan 13, 2009 | Toshiba SD-K860 DVD Player
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | Televison & Video
No sound on cd, (kenwood kdc-x469)
did you try another cd maybe your player needs a little cleaning and is your cd new or older
reason i ask is cause newer cd's have a different format then older cd's from a year ago its getting hard to play new stuff on old stuff
May 06, 2008 | Kenwood eXcelon KDC-X469 CD Player
Kenwood Unity System Logo
110 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
