Question about Mitsubishi WT-46805 46" Rear Projection Television
Mitsubishi WT-46805 Sound but no Picture..
Turns on but and there is sound but no picture.. menu will pop up but all three colors are not even with each other... Blue screen will come up on channels with no signal.. But when you use a video input or a regular channel only sound comes out and the screen is blank.
  • Anonymous May 25, 2009
    i have the exact same issue. Not sure what is going on.
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi big screen tv model no. wt-46805 year2000
Replace the convergence amp ICs. also shck the resistors coming out of the ICs
Posted on Feb 03, 2008
  • 979 Answers
SOURCE: MITSUBISHI vs-7083
What is your source? Antenna, cable, or satellite?
accordianman
Posted on Feb 22, 2008
  • 927 Answers
SOURCE: Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Good Luck, big IRISH.
Posted on Jul 25, 2008
asnowman
  • 788 Answers
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I think that you have two that are on the board in the center of the set. They are secured to a very large aluminum heat sink.
There are two ways to repair intermittent connections on the convergence IC’s. I usually remove the board with the convergence IC’s on them and then and solder the connections. The other method is to tilt the circuit board and solder them while still installed in the chassis.
If you remove the board and repair the connections, be careful to remember which connections need to be made when you replace the board. Mitsubishi uses a lettering system, so it should be easy.
If the problem remains after you have made the repair, it is possible that the pins on the IC’s have become loose. In this case the IC’s need to be replaced. I have seen this on several occasions.
If you choose to repair the set yourself, be very careful of the high voltage that can be stored in the capacitors, and CRT’s. This voltage can be as high as 30,000 volts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on May 29, 2009
gopakumarg43
  • 74871 Answers
SOURCE: I have a 73 inch Mitsubishi television the indicator light stays on when you turn it on... no picture shows and when it turns off that's when you hear the sound. the model number is WD 73642
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Jan 15, 2017
The picture on my tv (mit. 1080) is made up of
Convergence ICs Two of them STK392-570 ,they are big black ICs,Replace with same Number on ICs.You can order them at MATS 1-800-628-1118.
Aug 07, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Jul 28, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Bad picture
Good Day, tater5;
Sounds like you have a convergence problem. If the picture is bowed, please repair as soon as possible before 'the problem' causes additional concerns. It sound's like the 'conv' IC's have failed.
If you are handy the convergence IC's are big and black and attached to a large heat sink and will have numbers like STK 392-something.
Not handy? Then call a factory authorized service dealer to fix this for you.
Jul 06, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Half Dead mitsubishi wt-46805
This condition can be caused by multiple failures, however this unit has chronic bad yoke connections. Difficult repair for a layman but not for a tech or shop. Most likely 200 to 250 for that repair. Other more serious failures sure to cost more.
Feb 09, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsu 46805 - No picture
this model has loose connections on the yokes remove the front speker gril and a small cover wigil the wires alittle and see if the pic comes back on if so solder the bad connections and put fresh solder on the verticl ic too
Oct 18, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Good Day, Corri;
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
466 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
