Question about Simpson Garden
I need a resealkit for a simpson AAA pump model #3530B-S Serial # 700680
Hi i have a Simpson washer and its coming up with a E20 error on model SWT5542
E20 means it hasn't pumped out properly. Check for blockages in the filter, kinked drain hose, coins or foreign material stuck in the hoses underneath. The pump may be faulty.
Mar 19, 2017 | Simpson Washing Machines
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
Simpson washing machine ezi650 still wont drain after installing new pump
Why did you change the pump? Had you tested the old pump & made sure it was faulty? You need a multimeter and test the pump, the wiring for breaks and then check that power is actually getting to the pump. No power - No go!! If no power then probably a fualt on control board.
Jun 13, 2016 | Simpson Washing Machines
Simpson eziset still eont dtain aftet nee pump installed
You need to confirm that power is getting to the pump, these machines can get broken wires between the control panel and the pump, usually half way up the inside of the cabinet.
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
Feb 21, 2015 | Simpson Garden
I have a Simpson 4240 h with aaa tri-plung pump. I am trying to remove the pump from the engine but don't see a set screw. I know there are two bolt holes that say 5/16" which I assume u run the bolts
no set screw then just four bolts from flange and yes you can ude bolts to extract but not recommended if frozen your best bet is to insert a tie rod puller in between the engine and pump and strike it with a hammer if you do not have enough gap try two small chisel and wedge one on one side carefully then insert other to the opposite end and chisel til you separate them.
Aug 09, 2014 | Simpson NEW PRESSURE WASHER 4200PSI PS4240...
I dont know what is the password for the simsons hit and run encrypted file
It is because you haven't bought the game simpsons hit and run. If you have bought it from a market, check that the disk contains the serial code or not. The serial code is usually in a TXT file named Serial ID, Serial Code or Serial.
If you can't find it, you should go to the market and buy original version of the game.
Jun 28, 2012 | Fox Interactive The Simpsons: Hit and Run...
How old is simpson auto sensing 512 drier
You would have to contact the manufacturer and give them the serial number. The date of manufacture is built into the serial number.
May 11, 2012 | Dryers
Diagram of how to replace drive belt on simpson sirocco 500 tumble dryer
May 12, 2009 | Dryers
Nero 6 serial number
i need a new serial number for my 6.6.0.13 verison
Mar 03, 2009 | Ahead Software Nero 6.0 (60045) for PC
Garden Logo
275 people viewed this question
Top Simpson Garden Experts
John Trevino
JOHN LAPIER
ray gallant
Are you a Simpson Garden Expert? Answer questions, earn points and help others
