Question about Sony KV-27FV16 TV
Sony Triniton not powering on
Sony Trinitron TV will not power on, no lights at all come on. Power Supply issue or should i just try getting the dust out of it?
    Genius:
  • 2,035 Answers
If the lights don't come on the tv ,try to connect the tv to the other power point
and check if it powers on, if its does not power on then its the problem with
fuse inside the tv replace the fuse and check its works ...and also test the power chord for continuity ..
Good luck...
Posted on Feb 18, 2009
SOURCE:
My Sony triniton tv won't power on because the
Every set has a standby power supply that runs 7/24 when set is plugged in---it means in this case a main power board or something associated with that is not working, Set is not making it from just standby to full on.
Dec 23, 2012 | Televison & Video
2002 36" Sony Trinitron XBR High Def TV. When you
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
Aug 05, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony Triniton 1997 TV worked fine until Saturday. Now no image or sound. can it be fixed?
Yes! I find in most cases it is due to bad capacitors in the power supply and high voltage area of the set, sometimes the capacitors develop a bulge at the top which indicates they are open.
Jan 17, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Why does the sony triniton 40in not turn on but the power button flickers red
Is it blinking a code? * * * * * * * * * * * * This would be a 4 flash. Count them and post the flash code.
Mar 17, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Triniton tv no longer working standby light blinks seven times. why is it on standby?
Could be a fault in the powersupplym could be a flyback issue it will need to be evauluated to see what is the cause now most shops will tell you what it is without charge that way you can decide to repair it or replace it I am telling you it could be a power supply issue or flyback I will need to look to rule it out but at least you know what the problem could be and determine the cost of repair. please do click the end session to your right,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 19, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Red light blinking 7 times on Sony Triniton Wega TV
This means one of three things, either the lamp is bad on your tv, the ballast that powers the lamp is bad or the safety switch for the lamp door is not depressed or it has come un-plugged. It could also mean the power supply or fuse on the power board is blown. I am assuming this is a DLP tv, and if so, it is fairly easy to fix it or find parts for it online. If you are slightly mechanically inclined, want to save money and dont mind paying attention to detail then you can fix it yourself. If you need help dont hesitate to ask.
Jun 21, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony triniton,no sound or picture,flashing red light blinking!
the main problem of your tv set is the main power or what u call the regulator.the red light blinking it means your tv set is on standby mode.
Feb 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony TV stuck in stand by mode
the 9 blink code is caused by a bad diode on the pc board. The zero crossing detect circuit is not allowing the power supply to come on .
Sep 06, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
36" Sony Triniton Wega
Hiii....
Loks like trouble in A board ( referee to blinking code ),the +13v is not supplied,so the power supply become stopped,the tv will back to standbay mode ?! check the ic561 : STV9379A ....
Hope can help you...
Thank's
[Vrya]
Mar 15, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-27FV16 TV Logo
355 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
