Question about iLO 3200 32 in. LCD Television
Remote control turns on and off but no other buttons work
My remote dosen't work... What should I do????
Posted on Feb 19, 2009
I just bought a new remote and cannot find the user guide for the TV. Do you need to program the remote for it to work?
Hello
You have to programme it. do the following:
[1] Make sure there are working batteries in the Toshiba remote control.
[2] Turn on your television set, DVD player or other device that you want to control with the Toshiba remote
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
[4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
[5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
OK.
Jul 19, 2011 | Toshiba DC-SB1 Remote Control
Tip
How to make Program for making an Universal Remote Control
<p><span>For making a universal remote control it takes few steps by using the Automatic Code Search method.</span><br /> <p><span><span> </span></span><br /> <p><span>First: Turn on the component that you want to make the program for universal remote control.</span><br /> <p><span> </span><br /> <p><span>Second: Now press the component button on your remote that corresponds to the component you want to the remote to operate such as TV, VCR, etc. The illuminated on-off button will turn on and keep on.</span><br /> <p><span> </span><br /> <p><span>Third: Press both component and on-off buttons. The illuminated on-off button will turn off, and then will come back on.</span><br /> <p><span> </span><br /> <p><span>Forth: Now release both buttons after the pressing on-off button turns back on. The button must remain illuminated.</span><br /> <p><span> </span><br /> <p><span>Fifth: Then press and release the "play" button. If the component does not work wait few seconds, than continue to press the "play" button every five seconds until the component turns off.</span><br /> <p><span> </span><br /> <p><span>Sixth: Finally press and release the "reverse" button when the component turns off, and then wait to see if the component turns on again.</span><br /> <p><span> </span><br /> <p><span>Seven: Press and release the "STOP" button to save the new code of your remote control.</span><br /> <p><span> </span><br /> <p><span>Now it is your new remote control that will work on your all component as universal remote control.</span><br />
on Dec 24, 2010 | Televison & Video
Ordered a new Toshiba SE-R0177 remote for TV model #15DLV16. New batteries installed. How do I set it up? It did not come with a manual and the original manual no longer exists. Can't find one online...
. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
Mar 17, 2011 | Toshiba Se-r0177 Remote Control
What are the codes for a toshiba tv?
  • 1
  • 2
  • 3
  • 4
  • 5
  • Mar 09, 2011 | Toshiba Televison & Video
    I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
    Try the following procedure:
    1. Make sure there are working batteries in the Toshiba remote control.
    5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
    Feb 28, 2011 | Toshiba Vc-260 Remote Control
    Not able to turn tv on with remote
    First try changing the batteries.
    Next make sure when you press function on the remote control the red light on the remote displays under tv
    Next try a remote reset:
    You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
    To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
    Aug 24, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
    My Sharp LC-32SB24U will not power on from the remote. It will work if you push the button on top. I have another sharp lcd in the house and I tried that remote also but it still will not turn on from the...
    Jun 01, 2010 | Sharp LC-32SB24U 32 in. LCD TV
    I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
    turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
    Mar 20, 2010 | RCA Universal Remote Control
    Unlocking my DVD Player
    Try this,it should work....Rod
    To change the current region setting on this player
    1. Press the Standby button on your remote control to place the unit into Standby
    2. Press the Standby button on your remote control to turn on the unit
    3. Press the Open/Close button on your remote control to open the drive tray
    4. Press the Clear button on your remote control
    5. Press the 1 button on your remote control
    6. Press the 3 button on your remote control
    7. Press the 6 button on your remote control
    8. Press the 9 button on your remote control
    9. Press the 0 button on your remote control
    10. Press the Open/Close button on your remote control to close the drive tray
    11. Press the Standby button on your remote control to place the unit into Standby
    12. Press the Standby button on your remote control to turn on the unit
    Jul 16, 2008 | Durabrand Televison & Video
    Remote control not working
    have you program first the remote control, to work on your TV..??
    Heres a few instructions how to programmed your remote..
    1. Test your remote control. To find out whether your remote control can operate the component without programming, turn on the component such as a VCR and press the corresponding MODE button (VCR) on the remote control, while illuminating on the selected component. Test the POWER button to see if the component responds properly. If not, the remote requires programming to operate the device.
    2. Turn on the component to be programmed, then press the corresponding MODE button on the remote control.
    3. Press the MENU and MUTE buttons simultaneously for 2 seconds, the button selected component lights on the remote control. If you don't press any button for 20 seconds, the button selected component will turn off on the remote control. At a moment, you have to repeat from step 2.
    4. Enter a code number using the number buttons on the remote. When pressing the button, the light is blinked at a time. Programming code numbers for the corresponding component can be found on the following pages. Again, if the code is correct, the device will turn off.
    5. Press the MENU button to store the code. After blinking twice, this code is stored.
    6. Test the remote control functions to see if the component responds properly. If not, repeat from step 2.
    Try 001 as the PCode.
    Thanks..
    May 08, 2008 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
    iLO 3200 32 in. LCD Television Logo
    Top iLO Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Jaime Hernandez
    Jason Morris
    Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
