Question about Kenmore 24032\24036 Top Load Washer
My belt from my kenmoe washer is broken. How do I get it out and put a new one?
  • onthethejob1
    onthethejob1 May 11, 2010
    how old is this unit,,they stop putting belts opn ,,unit 20 years ago..send model #...onthejob,,,i believe you mean motor coupling
  • 15,935 Answers
It appears your belt has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Broken belt
Buy new belt for washer, pop off back plate, put new belt on.
Dec 10, 2013 | Bosch WET 2820 Front Load Washer / Dryer
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
Hey bud, i replaced my kenmore washer with a new coupler, but still it will not spin??
inspect under the washer. look at springs for broken or one that may have come loose. inspect drive belt for broken or off pulleys. the drive belt is not turning pulleys, belt maybe broke or outa pulley grooves. or belt tension springs are broken or unhooked. good luck!!
Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
I have an amana washer...Model # 8318015...The belt is broken..I have a new belt that I need to put back on, and I need directions on how to do this
take the bottom panel out(2 screws) then the upper panel out(its clips)
now the pump need to take off the shaft 3 screws then you can put the new belt in it with tention from the pully roller... try to see if there are video for that in youtube...good luck not so EZ to do :(
Jan 02, 2010 | Amana ALW480DA Top Load Washer
Belt broken on my wdt1085 washing machine.
take off back plate to washer, wrap belt round motor and spider (6 legged wheel above the motor) and turn the spider thats it
Jun 23, 2009 | Zanussi F1045W Front Load Washer
My kenmoe washer starts filling up with water but won't fill up. Water is just keeps running through but won't hold the water.
You drain hose must be higher than the tub. you can solve this with a standpipe or a siphon break kit.
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
MAYTAG WASHER SAV205DAWW
This calls for some dis-assembly of the washer. Are you still looking for assistance ?
Jan 01, 2008 | Maytag Legacy Series Top Load Washer
New belt
First put the belt around the small pulley, shd be the motor pulley i think. Then ease the belt around the big pulley & gently move clockwise if the pulley is on the left side; anti clockwise if you are inserting on the right side. The belt will fall into place. Actually it is very simple.
Apr 18, 2007 | Maytag SAV4655A Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
35 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
