Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
I need to change the door gasket on my Whirlpool dishwasher
My Whirlpool dish washer has been leaking sporadically for a few weeks now. I am pretty sure that it is the door gasket as water only drips from the bottom left door area. Any advice on how to change this gasket?
Thanks!
  • Bosch Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
uioypoiy[
Posted on Sep 29, 2010
Dish washer leaks suds from the bottom of the door. When it was run with no soap it did not leak. I am using the same soap pods I have used since it's purchase, 1 1/2 yrs ago.
do not call that repairman again. check to see if gasket/seal is cracked and if the door can be adjusted to close tighter
Aug 06, 2015 | Maytag Dishwashers
Dishwasher leaks from the bottom of the door
Hi, if it is leaking around/under the door, it must be the seal around the door. Check to see if the seal needs to be pushed in somewhere or is damaged..
Try running the cycle with no dishes in the washer and see if it leaks, it sounds like a gasket in the door to me and you can also check hose by removing the front panel on floor and check there....
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and re tighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Jun 26, 2011 | GE Nautilus 24" Built-in Dishwasher
Dishwasher keeps leaking from door
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Jun 22, 2011 | Bosch SHU9915UC Dishwasher
My dishwasher door drops down way too easy for my whirlpool partner iii. my wife found a black thin gasket under the dish washer. how can i fix the door?
replace both door balance cord assemblies on both lower sides of the door where they hinge onto the tub assembly as they are counterweights for the door
Apr 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Kitchenaid dish washer kuds24sewh4 door leaks but does not seam to be gasket ! water drips from inside of door bottom? possibly rinse aid leaking in door?
remove the inner door panel and ck for leakage . there should be water tracks . / there is a bottom seal. that may be failing / ch to see if its in proper possion .. its on the tank under the door / open the door all the way and look from inside to see. ( with a light .. mm
Dec 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
WP Dishwasher leaks when washing but not when draining.
This type dishwasher has a gasket/seal beneath the lower rack (sump gasket)
You would be able to see it if you pulled out the lower rack and removed the lower arm and filter (please only do this if you are mechanically inclined. Also, replacing a sump gasket is a MAJOR repair and pretty tough to do. You don't say how old this dishwasher is but if it is more than 4 years old, unless you have an extended warranty, it is probably best to replace rather than call for repair service.
Mar 28, 2009 | Whirlpool 24 in. DU948PWPQ Built-in...
Bosch SHU4322 Dishwasher leaks in the door
Detergent dispenser gasket or faulty air vent.
Feb 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
221 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
