Question about Fuji Finepix Z20fd Digital Camera
My Fuji finepix camera will not connect to my Max OSX
I used to connect by holding down the green triangle for a few seconds but now that does not seem to work!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Posted on Dec 28, 2012
cammedic
  • 667 Answers
SOURCE: softwear for finepix camera
The A202 is a European model and they do not have updates for Vista that I could find. You can however find the updater program for the FinePix software that includes Vista. http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportSoftwareContent.jsp?dbid=864214&prodcat=644675&sscucatid=664260
Posted on Jan 05, 2008
  • 65 Answers
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
Posted on May 28, 2008
SOURCE: Fuji Finepix Z1 Zoom Error
hey
i had the same problem with my z1 camera aswell
and it got really frustrating so i tried different things, like turning it off and on again, taking the battery out etc
but i think ive found the solution to this problem,
when you turn it on you get the zoom error grrr
what i did was open the slide and as the camera is turning on hold down the 'take picture' button at the top and the camera is like normal
it worked for me anyway
hope it works
Posted on Jun 26, 2008
robmcd27
  • 423 Answers
SOURCE: memory card not working? ( fuji finepix Z20fd Digital Camera)
Hi there.
When you start using a memory card, you must format the card in the camera first...using the camera menu. If you don't the camera won't read the card properly. Try that and I bet it will work for you.
Rob
Posted on Mar 09, 2009
  • 3 Answers
SOURCE: Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
Posted on Oct 13, 2009
I just bought a Fuji finepix xp60 camera. I have a Mac OSx 10.7.5 (on the box that this camera is compatible with Mac). Tried connecting to camera with image capture and iphoto and finder. No luck. ...
Consider NOT connecting your camera to your computer.
Aug 09, 2013 | Fuji Finepix Xp30 Waterproof Freezeproof...
Fuji film finepix JX250 how can I copy pictures from internal memory to a memory card
Press the playback button (right-pointing triangle). Press the MENU/OK button. Use cursor-up/down to select "COPY". Press cursor-right. Select IN -> SD and press cursor-right. Use cursor-up/down to select ALL FRAMES and press MENU/OK.
Jun 15, 2011 | FUJIFILM FinePix JX250 Digital Camera
I have a Fujufilm Finepix S5700 digital camera. Does not power up
hold power button down and remove battery at the same time once battery is out put battery into charger, if the light shows red then it needs to be charged if it shows green allow it to stay in the charger for 3 minutes then remove the battery and install in the camera pust the power button on hold for 5 seconds, if the camera comes on your ready to go, if not then you may have damaged the battery pack and will have to replace te battery. If you have a cable that plugs into the camera try using the powrord with battery plugged in, if it does not work then your battery is bad and you will have to purchase from fuji to get the right battery pack.
Jun 13, 2010 | Fuji FinePix S5700 Digital Camera
Hi
Hope it helps!
F
Sep 28, 2009 | Fuji FinePix S9000 Zoom Digital Camera
After several shots the camera takes too long to reset. The led light just keeps flashing from orange to green and can take up to 2 minutes before i can take next shot
How big is the card you are writing to?
If you are using large format card this will slow the camera down to turtle speed. Try iusing a lower value card 2GB Max
Thanks for using Fixya+++ Please rate our help
Sep 23, 2009 | Fuji Finepix Z20fd Digital Camera
Fuji finepix e510 won't turn on
If your Fuji e510 battery system is like the Finepix S3000 or the S3100 take a look at the following postings: Finepix S3100 (Camera power does not come on...) by banobo of Feb 07,2008 and check out solutions #2 & #4, (Mine is #4), Also see posting by "tomawamba for Fuji S3000" and my slightly differently worded solution.(Only one posted). May be best to get camera working before connecting with anything else. Good luck, be patient.
Jan 18, 2009 | Fuji FinePix E510 Digital Camera
Time exposure shot
Hi - You can download the manual by clicking the link underlined in blue below:
FinePix S5200
The max exposure time is 15 seconds. See page 42:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 03, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Not recognizing my camera
Check your Mac OS X version number then go to the website below to download appropriate updater for your finepix viewer program.
Mar 31, 2008 | Fuji FinePix A345 Digital Camera
Fuji Finepix split screen
If the picture taken from digicam are ok when viewed from a computer, the lcd viewer has a loose connection or defective already, if you can open your unit, try to disconnect and reconnect the lcd flexwire inside.
Oct 15, 2006 | Fuji FinePix S2 Pro Digital Camera
Fuji Finepix 50i won't switch off & has frozen.
There are a few things you can try. I had a fuji that would sometimes do this also. I found low power was one of the main issues. First try a new set of NiMH as alkalines just wont cut it specualy with these older cameras. Next check the memory card door. There is a little tiny switch on the memory door that will turn the unit off if the door is opend. Make sure the door is fully closed and maybe even hold it down tite while you try and use it.
May 03, 2006 | Fuji FinePix 50i Digital Camera
Fuji Finepix Z20fd Digital Camera Logo
27 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
