Question about Maytag Atlantis MAV6000 Top Load Washer
Water fill, discharge and noise problems
My Maytag Atlantis, top loading Model #MAV1754 EWW does not fill up full for large loads. Water slows down when filling from the hot water side, yet works great for warm or cold water. The last problem was seeing water spraying straight up and out around the drain hose area. Checked all my plumbing and it works great until I put the washing machine drain hose back into the drain hole. I took it out and ran a garden hose with water, to see if the pipe itself was stopped up. The water ran into the discharge hose perfectly.My washer is very noisy when washing clothes, too. It has this brown plastic accordion type hose for the water to run out from the washer. (I highly question this type of hose)
  • kbontke Feb 18, 2009
    I will certainly try this! As for now, because of the water spurting everywhere, I have to take the drain hose off to see if it is clogged and check the filter too.
    Thanks so much for the speedy reply!
    kbontke
  • 10,865 Answers
To reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Posted on Feb 18, 2009
  • Joe Hogan Feb 18, 2009
    you are so welcome. please rate my answer as a fixya!
    thanks and good luck to u
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Water when filling has slowed down cold water is very slow hot is ok
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Hello, at times when machine has completed final cycle laundry is still very wet. I must start a second spin cycle to remove access water. medium loads. thank you John
make sure the drain hose in the back is as high as the machine and is not being slowed down in any way. if the water is not getting pushed out fast enough this can cause thisto happen. another thing is you might be putting to much clothes in it try it on a large load but half full of clothes see how that works. good luck
Feb 24, 2011 | Maytag Atlantis MAV8551 Top Load Washer
Won't start
if it filled proplerly and won't start now, it sounds like the door switch is broken, there could be something wrong with the rest of the electrical systems, however i would suggest the switch first. If there is a lot of noise like its trying to run, then its probably your transmission.
Jun 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Water will not drain, will not do anything.
I would check the lid switch. That is most likely the problem.
Apr 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Washer (approx. 7 years old) has slow stream when filling
Follow the two inlet hoses from the back of your machine. They should each end at a valve (one for hot and one for cold). Make sure that these valves are all the way counter-clockwise and that the hoses are not kinked or pinched.
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Fills with water than nothing!
Most likely it's the lid switch, part number 22003804.
Remove the back of the console to gain access.
Jan 22, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
137 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
