Question about Kenmore 41042
My Kenmore 417-41042 won't dispense bleach/fabric softener? Can I fix this? If so how do I get to the part that needs replacing? Thanks in advance for your help.
  • rwtemp Feb 18, 2009
    Maybe I wasn't clear.
    My washer has both a bleach and a fabric softener dispenser.
    Neither one is dispensing.
    We don't use the "bleach dispenser", but the fabric softener dispenser isn't working???
  • pmbmail May 19, 2009
    I have a 1999 Kemore 417 front-loader and almost never use bleach. I tried to use it today, and it would not dispense.
    Genius:
  • 1,075 Answers
When you mention{ bleach }what do you mean.to run bleach through a machine is trouble theres not a washing machine capable of running bleach: in fact if you look at your hand-book youl find it does not recomend this practice .according to how long you have been doing this my advice would be to not to use bleach any more.adrian
Posted on Feb 18, 2009
How do i remove the drawer to clean it out the bleach, softener, detergent dispensers?
The dispenser slides out . There are plastic slideson both sides of the outer dispenser tray which run into grooves internally . be careful not to force its removal as you will damage the tray
Feb 10, 2015 | Kenmore Washing Machines
Water is still in my liquid bleach dispenser after load is finished. is this normal?
If it is just water then it could be OK. Most companies use a water stream to flush the bleach and also the fabric softener out of the dispenser systems and into the washer tubs. Some water left over is probably normal as long as the bleach or fabric softener has dispensed.
Sep 19, 2014 | Kenmore Oasis153; Agitator 4.5 cu. ft....
Kenmore frontloader fabric softener dispenser is clogged
There should be pins located somewhere on the dispenser or a grey thing located inside the dispenser, push it down and that will release the dispenser from the washer. Afterwards you can put in in the dishwasher, this should clean out any clogging residue.
Mar 10, 2013 | Washing Machines
Fabric softener compartment
You will need to clear the line from the fabric dispenser to the tub.
Oct 15, 2012 | Kenmore HE2 Plus Front Load Washer
Fabric softener/bleach dispenser full of water
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2009 | Kenmore 46462 Front Load Washer
Fabric softener dispenser will not dispense ...still full after a load. Soap appears to be working fine. Not sure about bleach.
softener is likely hardened on the solenoid. the dispenser must be removed and cleaned.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Jan 10, 2009 | Washing Machines
Bleach dispenser Kenmore Elite HE4t Model 45986400
is the machine level or is something plugged anywhere?
Mar 27, 2008 | Washing Machines
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
137 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
