Question about Mitsubishi WS-48613 48" Rear Projection Television
Need to reset Mistubishi 48 rear projection tv.
While the tv was on and in tv viewing mode my daughter pressed a button (I don't know which one) on the remote that came with the set and then I pressed a button to change channels and immediately the tv goes into PiP mode of which we cannot get it out of now. When we press the power button to turn on the set a blue screen appears which if we want to play video or dvd we need only turn on one of those players and the image will appear. However to get to the tv viewing mode we must press PiP (5) buttons in a sequence that allows for tv viewing. To say the least pressing 5 buttons to get tv is a pain. We unplugged the set for a day to reset it but that did not work. Is there a way to reset it?
HOW DO I SET MY MITSUBISHI VS5041 I HAVE IT CONNECTED TO A HOME THEATER SYSTEM AND IT PLAYS DVD MOVIES BUT I CANNOT SEE ANY TV CHANNELS
Posted on Dec 22, 2009
    Genius:
  • 2,035 Answers
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "2", "2", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
NOTE: At this time channel 3 is automatically selected.
This will reset the the tv ....
Posted on Feb 18, 2009
Tip
Reset Mitsubishi WS-48511 VChip Password
Bypass or Reset Mitsubishi WS-48511 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi WS-48511 Front Lock
Mitsubishi WS-48511 Manual Download
on May 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
My tv is locked and asking for a an unlock code. I have never had a lock code on the tv since i bought it several years ago. How can I reset or bypass this feature. BTW mt TV is a 48-50" projection...
Hello
I thinks that you have its original remote handset with you now, and posts this solution. If you don't have it, either buy a new original remote handset or try to get it from any of your friends and relatives, who owns the same model of Mitsubishi Tv, you have now; only to unlock it. After unlock, you can use any other remote control.
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
OK.
Sep 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Sony 46in projection tv
To reset this unit start with pwr off. Then on oringnal remote press the display button, the number 5 button and then volume up button and then hit the power button this will take you into the service mode menu, Press the number 8 key and then hit enter, this will set the unit back to factory specs. The set should turn off itself and then power on itself to channel 3, All user setting before this procedure are reset to factory mode..
Please leave comment THX
Nov 04, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
How do I reset Lamp in PT40LC12 with out a remote
After turning on the TV and viewing the message to "reset the lamp" I became frustrated and attempted to shut the TV off by pushing the power button. A message popped up saying "Do you want turn the TV off Yes / no.
I toggled down using the volume/Channel button on the tv to say no. The next thing i know...The TV picture came on and the la,p was reset!!! I really don not know how this happened! but it worked! Thanks for your assistance. Now, i can program a remote!
Oct 23, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Plasma problems
It's in standby mode.
Let's do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
Let me know how this works
Jan 30, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Can the WS-55819 be reset through a reset button?
Code 22 is short protect. Recheck your work. Did you check and replace open fuses and/or Convergence IC's. The Conv. IC's normally open at least one fuse when they go out.
Nov 02, 2008 | Mitsubishi WS-55819 55" Rear Projection...
JVC AV-48WP30 48 in. Rear... Problem:
Take the batteries out of the remote control. Press every button 2 times. Then re-insert the batteries. While doing this unplug the TV and hold the power button down for 30 seconds. Then let go and leave the TV unplugged for 3 min. Then turn tv on do a channel scan and then try yhe remote.
Jan 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Double vision
The double vision is from bad convergance ic's and posibly some support resistors or pico fuses. if you are not an electronics tech I suggest to have one do it. the ICs can range from $45.00 to $60.00 each and is suggested to replace both of them. some mitsies had one IC which I cant remember how much it was. tech charges vary. some prices may be $150.00 to $300.00 shop around.
Dec 31, 2007 | JVC AV-48WP30 48" Rear Projection...
Colored Lines at the top of the picture
To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset.
Sep 19, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
268 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
