Question about Pioneer DEH-P470MP CD Player
I want to enable AUX function, but pressing the function button doesn't bring that option around? Would disconnecting the power reset things?
  • sctyp33 Feb 18, 2009
    Nope, did that - no dice. It was there once upon a time, but now seems to be gone???
    Problem Solver:
  • 4 Answers
How about trying the source button.
Posted on Feb 18, 2009
How do I connect a Phillips t v to the internet
Either with an Ethernet cable from your home internet router to the TV, or wirelessly. The 4200 series require an optional wireless dongle (PTA127) to enable wireless functionality.
You can use a 3rd party wireless or Ethernet over Power devices (Homeplugs) to bring an internet connection to the TV that can then be connected to the TV's Ethernet port.
Sep 09, 2014 | Televison & Video
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
Need a manual- Pioneer DEH-P440
ok, i dug up my old manual and i guess i was wrong,
straight from the book:
1 Press FUNCTION to select AUX.
Press FUNCTION repeatedly until AUX appears
in the display.
2 Select AUX on or off with ^/v.
Pressing ^/v will switch AUX between on and
off and that status will be displayed (e.g.,
AUX :ON).
and as for t-scan: T-Scan play lets you hear the first 10 seconds of each track on the CD.
Apr 29, 2010 | Pioneer DEH-P440 CD Player
What is the aux button for?
(AUX BUTTON) silent mode tm and an optioal auxiliary function are controlled by pressing this button.(silet mode works by pressing this button for less than 1 second before arming or disarming.an optional auxiliary function,such as trunk release,can be controlled by pressing this button for 1.5 seconds.)
Aug 12, 2009 | Viper Security and Remote Start System...
Put in new car battery, now can't get aux to work
Hi there
hold down the source button to turn off the unit (unit must be off)
now hold down the function button till it beeps once it has done this press the function button i think 3 or 4 times and you will get a message on your deck unit saying (aux - on,off) turn on and press the source button to turn the unit back on to the CD or radio now press source button2 or 3 times till Aux shows up (press means push it let it go) (hold means don't take your finger off button)
hope this solves your problem
Oct 11, 2008 | Pioneer DEH-P4700MP CD Player
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
Finding the AUX button
With the stereo on, hold your Source button to turn the stereo off.
The hold the function button, a menu will appear, press function repeatedly until you see the Aux setting, and you will have an option to enable it with the navigation keys.
Once done press your source button to turn the stereo back on, and then go through the varioud sources and ye shall now find Aux as an additional source ;o)
Dec 05, 2007 | Pioneer DEH-P8200r CD Player
AUX????
IS THERE A FUNCTION BUTTON IFSO PRESS IT REPEATEDLY UNTIL YOU GET TO AUX ZAZWPX
Jun 06, 2007 | Sony CMT-EP515 CD Shelf System
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-P470MP CD Player Logo
181 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
