Question about Kenmore 23822 Top Load Washer
Kenmore 90 series- The drive coupler broke. so I replaced it with no priblem. Motor and pump spin by hand. But when i put back together and turned to spin cycle it just hums. Any solutions?
  • dianestauffe Feb 24, 2009
    MY MOTHERS TOPLOADING KENMORE WASHER#11020902990 WILL FILL WITH WATER FOR SPIN CYCLE,BUT WILL NOT SPIN.SO CLOTHES ARE STILL FULL OF WATER.WHAT IS WRONG.SHE IS ELDERLY AND CANNOT BUY A NEW MACHINE. I CAN GET MY NEIGHBOR TO FIX IF I KNOW WHAT PARTS I WILL NEED TO BUY.THANKS FOR YOUR HELP.
  • 50 Answers
Does it pump out? Could have a faulty lid switch. The units will normally agitate but will not spin out.
Posted on Feb 26, 2009
My Kenmore washer is making a whining noise and will not spin. I took the clothes out and tried to spin agitator by hand. That was fine. However, machine started whining again when power turned back on. It...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020702991/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Three possibilities: since you can hear the motor (Ranging from easiest to messiest) None of the suggestions are very expensive.
You have to go through / check the first two before getting to the third.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams and spin gear.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit or spin gear, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Dec 20, 2010 | Kenmore Washing Machines
I have an older, but in good condition, Kenmorre 80 series top loader washing machine. The spinning won't move or when it starts washing, the arm in the middle doesn't spin the clothes around. Would it...
The Sears series numbers (70, 80, 90) only mean how many "bells and whistles" a washer has. The most important thing is the full model number. Usually a number starting with 110.########.
Most models don't use belts anymore but use a Motor coupler.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
damaged.
Nov 21, 2010 | Kenmore Washing Machines
Kenmore series 70 #11026732500 spin problem
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26732500&pathTaken=partSearch
I'm assuming that you mean that the washer won.t spin with a load but will without one.
Two possibilities:
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
As an aside, the long pole (agitator shaft) shouldn't turn if you hold it when the washer is in spin mode. Basically, the oil "friction" within the gearcase is turning the shaft when in spin mode and if you hold it, it shouldn't turn.
When the washer is in spin mode, the "drive tube" which turns the drum is driven by the clutch.
Also see the following for how these gearcases work and how the agitator shaft is released by the "agitate cams" when in spin mode.
May 27, 2010 | Kenmore Washing Machines
I have a kenmore 90 series washer. spins but not hard enough.
It's quite possible.
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Mar 27, 2010 | Kenmore Washing Machines
My Kenmore 90 series washer motor runs but the tub does not move
Mar 26, 2010 | Kenmore Washing Machines
My Kenmore 90 series model 110.28922791 is not spinning enough water out of the clothes.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.28922791
NOTE:
While you've got the pump out, I'd check the hoses to and from the pump as well as looking for any blockage in the pump itself.
Jan 28, 2010 | Kenmore Washing Machines
I have a Kenmore 90 series top loader washer. It
Two possibilities:
1.
2.
It's possible (if the motor coupler is fine) that one or more of the Neutral Drain Assembly gears , or the main Spin Gear in the transmission have broken.
See the Whirlpool / Kenmore service manual for a description of what these gears do.
In order to check them, you'll have to pull the transmission.
When ours had a similar problem and after looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If that's the problem, install a Neutral drain kit or main spin gear, put everything back together carefully and the problem may be solved.
Jan 26, 2010 | Kenmore 15864/15862 Top Load Washer
Fills the hums loudly
Hello , Have you looked inside the pump where the hose comes from the tub , there could be an item clogging it , also try turning the pump where the shaft goes by hand , it should turn freely.
You can also try turning the gear case with the motor off where the coupler is attached , 1 direction will agitate and the other direction spins , you should be able to turn the gear case both ways and it will not turn easy.
if all of these check out the motor could be bad but it is highly unlikely.
let me know how it works and if you have any other questions.
Phil
Jan 08, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 23822 Top Load Washer Logo
131 people viewed this question
Sal De
fordexpert
Robert Rankin
