Question about Karcher 2500 PSI Pressure Washer
I NEED A FUEL PUMP FOR A HONDA 5 HORSE - Karcher 2500 PSI Pressure Washer
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mr o, you need a fuel pump,i need the model#,type#,code#,of this engine if im going to help you.MrFixIt.
2005 Honda CBR 600 RR fuel pump not priming
Hi, Houston the following is a systematic procedure for diagnosing fuel pump issues designed to keep "DRACHMA" to a minimum. If you need parts check with Amazon and eBay first to keep costs down.
1. If your pump does not turn on check the pump fuse and relay and all wiring including connectors for corroded, broken, or loose pins/sockets.
1. Normal fuel pump pressure is 3-5 PSI.
2. Check any rubber or plastic tubing for age-related pinholes by removing and plugging the ends that connect to the fuel valve and then turn on the ignition switch and watch for fuel streams exiting the pinholes, if any exist, replace tubing as necessary.
3. Check for a clogged a primary fuel filter that comes off the bottom of the pump to screen out big rocks and clean as necessary.
4. Check for a clogged secondary fuel filter that's outside if applicable by removing it from the system and replace it with a short splicing tube turn on the ignition switch and recheck fuel pressure if pressure increases to normal pressure you need a new secondary filter.
5. If all the above check out OK and the pump is not functioning properly then you need a new fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Fuel pump not priming
fuel pump not priming CBR Forum Enthusiast forums for Honda CBR Owners
2005 2006 Honda CBR600RR Service Manual Moto Data Project
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Apr 09, 2014 | 2005 Honda CBR 600 RR
Need to know the fuel pump pressure for a 2002 Honda VT 750 CD Shadow
Hi, Anonymous the following is a systematic procedure for diagnosing fuel pump issues designed to keep "DRACHMA" to a minimum. If you need parts check with Amazon and eBay first to keep costs down.
Roadside fuel pump failure tip VT750DC
Fuel pump or relay ACE Maintenance
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
Mar 31, 2014 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
2006 Honda Metropolitan new fuel pump not working
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2006 Honda Metropolitan Scooter Starting Issues
Honda Metropolitan Fuel Pump and Gas Filter Replacement
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Honda CHF50 2007 Metropolitan Owner Manual
Oct 25, 2013 | 2006 Honda Metropolitan
2003 Honda CBR 600 RR fuel pump not coming on
Hi, Pedro the following is a systematic procedure for diagnosing fuel pump issues designed to keep "DRACHMA" to a minimum. If you need parts check with Amazon and eBay first to keep costs down.
http://www.fireblades.org/forums/honda-cbr-600/82760-got-power-fuel-pump-isnt-runin-when-turn-key.html
2003 2004 Honda CBR600RR Service Manual Moto Data Project
Oct 01, 2012 | 2003 Honda CBR 600 RR
2003 Honda VT 750 CD Shadow fuel pump psi
VT750C fuel pump testing
https://www.amazon.com/GoodQbuy-Replaces-VT750C-VT750CD-VT750DC/dp/B01N1QGBE5
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2001 VT750C3 Owner Manual
Aug 05, 2012 | 2003 Honda VT 750 CD Shadow A.C.E. Deluxe
2005 Honda VTX 1800 fuel pump won't prime
Can hear fuel pump prime up
Another Fuel Pump Not Priming Issue
Honda VTX1800R Owner Manual service manual, not owners. https://www.partsfish.com/page/oem-parts-for-honda
Jun 02, 2012 | 2005 Honda VTX 1800
2007 Honda CBR 600 RR fuel pump not priming
Hi, D_justin16 the following is a systematic procedure for diagnosing fuel pump issues designed to keep "DRACHMA" to a minimum. If you need parts check with Amazon and eBay first to keep costs down.
2007 2009 Honda CBR600RR Service Manual Moto Data Project
Jun 23, 2011 | 2007 Honda CBR 600 RR
1982 Honda Magna fuel pump does not work
Hi, Allen the following is a systematic procedure for diagnosing fuel pump issues designed to keep "DRACHMA" to a minimum. If you need parts check with Amazon and eBay first to keep costs down.
Fuel pump trouble
http://www.magnaownersoftexas.com/forums/index.php?topic=4204.0
Honda 1986 VFR 750F Shop Manual
Honda 1986 VRF750F Owner Manual
Aug 27, 2010 | Honda Motorcycles
2003 Honda STX 1300 Pan European fuel pump not starting
Hi, Rolf_stuber the following is a systematic procedure for diagnosing fuel pump issues designed to keep "DRACHMA" to a minimum. If you need parts check with Amazon and eBay first to keep costs down.
Thread Fuel pump refusing to prime pump
Fuel Pump won prime
Honda 2003 ST1300 Service Manual
Honda 2003 ST1300lA Owner Manual
May 08, 2010 | 2003 Honda STX 1300 Pan European
I need to find the wire in dashboard for fuel pump(Vti-Civic-99)
Where is the fuel pump located on the Honda civic 1.8 Vti 5 door car?
Feb 01, 2010 | 1999 Honda Civic
Karcher 2500 PSI Pressure Washer Logo
76 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
