Question about GE Advantium 120 Convection/Microwave Oven
240volt Advantium making noise
I have a 240 volt advantium (over range) oven which is making a buzzing noise at rest almost like a mechanical clock is running which of course isn't since there isn't one in this unit. Seems to be working fine except for the annoying buzzing sound?
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Advantium won't heat
Actually, these have a 10-year warranty on the magnetron and on the halogen speedcook lamps.
GE will even send you the magnetron to replace it yourself. Call them at 888-239-6832.
The full service manual with installation instructions is here.
Part ordering help (if you need other parts) is here.
I'd recommend that your bookmark this link to your favorites.
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward. Thewy are in the service manual.
You can also download GE owner's manuals and installation instructions
here.
If you prefer to replace it though, I would suggest doing Google searches to try to find 240V microwave ovens. They're the exception.
Posted on Jan 11, 2010
Testimonial: "Fantastic response; providing me information I otherwise would not have known and potentially saving me from making a very costly mistake in replacing"
I have an Advantium 240 mounted over the range. There's a little trap door that covers an interior light while cooking. My door gets stuck and I hear a motor run. How can this be repaired?
That's the damper. It has to be closed when microwaving, and open when convection cooking.
See my video and also see the description text here GE Advantium microwave oven clicking noisy SCA1000 SCA2000 for more information.
Please note the phone number in the video is incorrect. See the Web site for more.
Nov 24, 2016 | Microwave Ovens
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
GE Advantium Oven Noise
Most are eqipped with a small cooling fan that allows the unit to cool down quickly..fan may need replaced
Jun 07, 2012 | GE Microwave Ovens
Re: "my GE Advantium SCA2001
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 31, 2010 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Apr 15, 2009 | GE Advantium SCA2000B Microwave Oven
Advantium 120 makes low buzzing sound all the time
this is the transformer that is doing it and it may end up failing soon , and should be replaced before any other dammage is done,
Nov 06, 2008 | GE Advantium 120 Convection/Microwave Oven
Black Metal Tray for GE Advantium Oven
I just found one for $33.95
http://www.partstore.com/GetModel.aspx?MfgName=General+Electric&BrandName=General+Electric&ModelNumber=SCA1001FSS001&page=3
Aug 26, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
148 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
