Question about Lowrance GlobalMap 3300C GPS Receiver
Need to know the connector brand and the functions on each pin
I have a Lowrance 3300C and need to connect it - Have no cables or plugs. I want to do a initiation to find out if, and how it works straight with what I have. The pin references if possible from the view side on the outside. I can only find the cable color connection, but no relation of the colors to which pin.
This is also to find out with a continuity tester or ohm meter or if the schematics are available.
I appreciate a link. Thank
Because Lowrance doesn't publish the pin connections, neither in their user guide, neither on a convenient website - this is really a breakpoint for me - I checked GPS connector suppliers and I found different plugs, type and connection codes in Europe, where information comes with the unit as a EU - norm
Posted on Feb 18, 2009
Installed new power supply on hp m470n cannot remember which wires go where HELP
The large power connector goes onto your motherboard--20 or 24 pin--in the socket provided. It can only go in one way.
There is probably a second connector, a 4-pin--that will plug into the motherboard near the CPU. It, too, can go in only one way.
Other than that, you just have to hook up the power to the hard drive and CD/DVD.
If you have a high-performance video card that has a power connection, it's probably a 6-pin connector.
var fctb_tool=null; function FCTB_Init_1fa6d7a6c9664247a0ca49a75c796f65(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_8ff702f2dff743098e4136310439f4e3(t) { fctb_tool=t; start(fctb_tool); }
Nov 13, 2010 | HP Computers & Internet
Unit turns on by itself
I have two Lowrance X 125 that I don't get any Power to.
Feb 07, 2010 | Lowrance GlobalMap 3300C GPS Receiver
Connect +plug in power - plug in
You cannot get this wrong.. The power plug is a 24 pin connector and it will only fit in one place on the board. You cannot plug it in wrong as it will only slide in the correct way. The 4 pin connector is the +12volt connector, again, you cannot plug this in wrong either. The power connectors to the drives are also 4 pin but they are a flat plug which again, cannot be plugged in the wrong way around. The data cables are very different. IDE cables are a 40 or 80 pin square connector. Each connector may have a key which fits into a socket on the mating connector so again, it will not go in the wrong way. If it does not have this key, then the red stripe on the cable shows pin one and if you look at the mainboard connector, pin one is usually marked on the board.SATA connectors are profiled, that is they are shaped and will only fit the one way. the power connector is a different size (its bigger) then the data connector so you cannot get these plugs wrong either..
Feb 06, 2010 | MSI 945GZM3-L Motherboard
I am receiviong a message " GPS Module Not Responding"
most cause by ant not working or bad cable or corrotion in connectors
Nov 09, 2009 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Jul 28, 2009 | Boating
Bought a 1995 Four Winns boat inthe dash it has a lowrance dept finder. under dash i see a 6pin male round connector & 2 pin round male hareness is there a harness i need to connect the 2 or what would...
Hi- I have a 1996 Four winns boat with the same problem. I believe we are missing an adapter cable which goes from the depth cable to the instrument panel. I have not been able to locate this cable yet. If I find it I will let you know and can you do the same for me if you locate one?
Jul 03, 2009 | Lowrance Boating
Lowrance 3300c still playing up
John, my 330c was doing the same thing until I found a short in a totally separate system. It was a speaker for the stereo. As soon as I fixed it, the flashing problem went away.
Jan 08, 2009 | Lowrance GlobalMap 3300C GPS Receiver
Gps
upgrade it firmware usnig the download support are in the main page of ur product u will find it there!!
Sep 10, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance GlobalMap 3300C GPS Receiver Logo
189 people viewed this question
Top Lowrance GPS Experts
buzz flewhart
buzz flewhart
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
