Question about Toshiba Satellite 1715XCDS Notebook
Power for the screen
I have got problem connect the two power Black and gray wires in the motherboard is there any one that tell where these wires connected to the motherboard with pleasure
ATX motherboard connector pin out
Black=0V(GND)
Yellow=12V
Red=5V
Orange=3.3V
Purple=5Vsb(everytime on)
Gray is PWRGOOD or PWROK(pwr=power) must be at 5v
White=-5V(optional)
Blue=-12V
Green is PWRon must be connected to a black wire to turn on the PSU
Nov 16, 2012 | Enhance Technology ATX-1123B, Enhance...
I turn it on and it powers up (the fan comes on), but nothing else comes on. The monitor won't come on, the keyboard does not flash, and I can't hear if the hard drive is doing anything or not.
This is difficult to diagnose without more information, but here are some things you can try.
If you have another monitor, plug that in and see if anything comes up on screen. Unless the motherboard is completely dead, when you turn it on, it should at least flash something (logo, some text, etc).
Check the connection from the power supply to the motherboard. The power supply is the big rectangular shaped box with a lot of wires coming out of it. It is usually gray, and on the outside it has the power plug connector. On newer motherboards the connection for the power supply is a double row rectangular wide plug. ragefuljoe.gif
However, from what you said, it sounds like the motherboard might be dead. The keyboard should blink, and on most motherboards the blink sequence tells you if there is a problem.
Feb 24, 2011 | Computers & Internet
Wiring diagram for BOSS AVA 1209 equalizer. It was given to me dont know where the 4 wires connect red,black,white,last wire is orange or pink.
Your wiring is as follow's :
The Red wire is your (+) Positive that connect's to the power source
The Black wire is your (-) Negative that connect's to the ground
The Orange wire is your Auxillary (+) that turn's on Amplifier's or Power Ant.
You should have a Green wire, a Green wire with a White stripe,a Gray wire, and a Gray wire with White stripe
The Green wire is the LEFT channel input (+)
The Green/White wire is the LEFT channel input (-)
The Gray wire is the RIGHT channel input (+)
The Gray/White wire is the RIGHT channe (-)
(BE SURE THAT YOU CONNECT THE RED (+) AND BLACK(-) WIRES BEFORE YOU CONNECT THE ORANGE WIRE TO AN AUX SOURCE OR YOU WILL BLOW THE INTERNAL FUSE !!!)
PS. I have no idea where that White wire you mentioned goes.
Feb 03, 2011 | Boss AVA1209 7-Band Car Equalizer
No power
Check for power supply power. Remove it from the motherboard and short or connect the green plus the black wire beside it. if the power supply's fan turns, then there's a problem with the motherboard.
Check for loose connection between the power supply and the system board. Apply WD-40 or contact cleaner on the contacts (mainly, this is a 24pin array connection) then unplug replug it to the motherboard.
Might as well check also for the power button's connection. Temporarily connect the reset switch to that of the power switch to check if the switch is the defect. Connect everything and switch it on.
Replug the memory modules including the processor but make sure you have a thermal compound handy to replace the gray/white paste-like matter between the heatsink and the actual processor.
Please do notify me if you need clarification, i'd be willing to provide a followup.
Hope this helps,
levibit
Dec 14, 2010 | ASUS P5KPL-AM SE Motherboard
Wires
Wiring Connections
1. TV TUNER
2. ANTENNA
3. POWER ANTENNA WIRE (Blue) – Connect to a motorized (power)
antenna and/or to a remote turn-on lead for an amplifier.
4. CONSTANT POWER WIRE (Yellow) – Connect the 12V PLUS constant
power wire to a live 12 volt wire in the vehicle. Before making a connection,
check that the wire you intend to connect it to is always live, even when the
car’s ignition is turned off. If a live wire is not found, route the wire to the
car’s fuse block and connect it to a live circuit there.
5. GROUND WIRE (Black) – Securely fasten the Ground wire to a grounded
metal part of the car’s chassis. If you cannot find an existing bolt or screw
to fasten it to, drill a hole in the metal and secure it with a screw. To ensure
a good ground, remove any paint or grease from areas where the wire will
contact the surface.
6. PARKING (Pink) – Connect to negative parking brake wire. This wire
MUST BE connected in accordance with federal, state and local laws. It is
the end-user’s responsibility to make sure this wire is connected properly.
7. ACC POWER WIRE (Red) – Connect to a +12 volt circuit that is only live
when the ignition is on. The best connection point is at the car’s fuse block
at the “RADIO” or “ACCESSORY” identified terminals.
8. LEFT FRONT SPEAKER (white, white/black)
9. RIGHT FRONT SPEAKER (gray, gray/black
10. LEFT REAR SPEAKER (green, green/black)
11. RIGHT REAR ( + ) SPEAKER (violet, violet/black)
12. FRONT AND REAR RCA OUTPUTS
13. CENTER RCA OUTPUT (Gray) – The center output must be connected to
an external amplifier for 3D or 6-CH mode.
14. SUBWOOFER RCA OUTPUT (Blue) – The subwoofer output is available
in all sound/audio modes.
15. DEDICATED DVD OUTPUT – Video output for rear screen and left/right
audio output for headphones.
16. AV1 INPUT
17. AV2 INPUT
18. VIDEO OUT (Yellow) - V. SEL output for rear screen.
Or you can go to link below for the manual page 4
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/VM9510_DOC_OM.pdf
Good Luck and please rate 4 thumbs for the free answer
Mar 31, 2010 | Jensen VM9510 Car DVD Player
What is voltage pin layout for the connectors on power supply model dr-b300atx
I assume you are talking of the 20 or 24 pin connector plugging into the Motherboard. Is it 20 or 24? Is there a 4 pin +12v connector plug. The colors of the wires tell a story. Red is +5V Black is Ground or Return. There is Yellow and Orange and Blue and green and gray. There are SATA connections . Look in your users manual of a standard Motherboard. This will give you a pinout and voltages on these pins. Write down the voltage starting with pin 1 and add the color to simplify knowing the voltages. If you're tech savvy, break out a multimeter for absolute certainty.
Mar 26, 2010 | Austin Computers & Internet
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
Jan 13, 2010 | Jensen CD4610 CD Player
Use the power supply outside the computer
Plug the power supply to desire voltage. Monetarily short the GRAY and BLACK wire in one second.
Sep 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Power sw -data +data
Did you get a manual with the board? Check page 1-20
You should find a pic just like this.
Wire colors. Black wire is ground - . Of all the case wire connectors the other common ground wire is white. Colors like red & blue are plus +.
It is much simpler to connect the case to motherboard LED's when the board is outside of the case.
Mike
May 03, 2008 | ASUS P4XP-X Motherboard
Echostar 450 watt switching ps
You need to short the ATX power supply to ON. Follow this steps. look for the GREEN and GRAY color wire in the power connection that usually connected to the motherboard of computer. Get a short wire and insert to the hole of GREEN and GRAY to short the switch. Good luck don't forget to rate my solution if helpful to you.
Apr 13, 2008 | Computers & Internet
Toshiba Satellite 1715XCDS Notebook Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
