Low or no sound
The power chip for sound test ok where to look? no info about any microchip any way of getting diagram? tv philips 20pt5441/37
  • 55 Answers
If the power chip is okay check the drivers. Make sure it's getting an input. Audio is picked off of the IF section. Make sure you have audio there and trace it out to the power output.
Posted on Feb 18, 2009
I am looking for a part number 056t562916 from a chip 705tp715022 for philips flat 19" tv panel! Please any help!
the service center of philips has a part number of it see the philips center for more info ok
Mar 25, 2011 | Televison & Video
Tip
42PFL7422D/37 Flat Panel LCD TV no picture no sound
I HAVE A 42 INCH PHILIPS MODEL 42PFL7422D/37 TV.
MY PROBLEM IS THAT IT HAS NO PICTURE AND NO SOUND.
THERE IS A GLOWING BACKLIGHTING.
THERE IS A BLUE LIGHT WHEN I TURN POWER ON THE TV. NO CLICKING RELAY SOUND.
MY PROBLEM WAS IN THE SLAVE INVERTER BOARD.
THE IC CHIP WAS BLOWN - SEE PICTURE. THERE IS A BURNED, DARK BROWN MARK ON ONE OF THE CONTACT LEADS ON THE CHIP.
THERE ARE $20 FIX IT KITS THAT YOU CAN BUY ON EBAY TO REPLACE THIS TINY LITTLE CHIP BUT IT'S RECOMMENDED THAT YOU SOLDER VERY CAREFULLY. I TRIED, AND DAMAGED THE BOARD SO I BOUGHT A USED ONE.
REMOVING THE IC CHIP IS PROBABLY BEST DONE WITH A HOT AIR SOLDER GUN. THEY COST ABOUT 50-200 DOLLARS.
AFTER INSTALLATION IT FIRED RIGHT UP.
IN ADDITION TO THE JUST BUYING ANOTHER INVERTER BOARD, I ALSO TESTED THE MASTER INVERTER TRANSFORMERS. ON THE POWER SUPPLY BOARD, I TESTED THE DIODES, AND RESISTORS, AND CHECKED THE FUSE.
AFTER ALL OF THE ABOVE, I UPDATED THE FIRMWARE BY GOING TO THE PHILIPS WEBSITE.
LUCKY FOR MY SITUATION IT WAS NOT THE MASTER INVERTER, MAIN , TCON, POWERSUPPLY, OR DAMAGED BONDING ON THE LCD PANEL ITSELF.
TOTAL COST $50.
GOOD LUCK!!!
on Dec 23, 2011 | Philips Televison & Video
Philips 28pt4523 tv - power on but no response to
check capacitors on power board if they are ok suspect is the tuner board
Mar 26, 2010 | Televison & Video
Sound is not coming but picture is ok in philips 21 RF vardan tv
sound is not coming but picture is ok in philips 21 RF vardan tv
Dec 16, 2009 | Philips 32PW6506 32" TV
Phillips 52'' projection tv.Picture goes small then large then off
Your original problem was/is an "opto" IC (chip),which causes the power supply to regulate low when it fails. It is a 6 or 8 pin chip. Sounds as if maybe more has failed now. Switch mode power supplies are not for the faint of heart,or DIY. I recommend having it troubleshot by a tech.
May 31, 2009 | Philips 50PP9202 50" Rear Projection...
The red light on the front flashes and tv wont turn on
1) Convergence chips are shorted....One quick test is to desolder and remove both STK392 chips....then power the set on. If the tubes light up the chips were shorted. You can get new ones from www.TvRepairKits.com
2) Another possible problem is a bad HVG - AKA the flyback.
Try the convergence chip test first. Note: On some Philips sets you can just unplug cable "1516" instead of removing the chips.
For instructions on how to find/remove cable 1516 visit the website listed above and click on their tips page. On that page click on the "Magnavox DPTV3xxx Checks" link.
Feb 13, 2009 | Philips 51PW9363 51" Rear Projection...
No picture, no sound, error code 7
Sounds like one of two problems
Jan 31, 2009 | Philips 46PP9302 46" Rear Projection...
PHILLPIS 60PP9202 MAKES SQUEALING NOISE WHEN TURNED ON.
Jan 29, 2009 | Philips 60PP9202 60" Rear Projection...
Philips tv
I have a 32 inch phillips tv that I bought from someone else and it has a child lock code on certain channels. How do I get this code off.
Jul 14, 2008 | Philips 21PT4475 TV
Philips 55PP9401 no sound no picture
When Replacing the (STK'S Power Pak) for this set you must use OEM parts. After market I.C. will not work!!! They will give you problems like you are discribing. D,TV
Dec 14, 2006 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
