Wireless home network problems I have 1 laptop and 1 desktop, both running MS Vista. I am trying to set up a wireless home network so that I can share files. I have a cable modem connected to a wireless router. Both computers are able to ''see'' the router and connect to the internet. The desktop can also see the Laptop's Windows Media Center and access the media files from it. But When I try to browse the Laptop I get an access denied message. And on top of that my Laptop does not ''see'' my desk top at all. I use the ''Nework Connection Wizard'' but still can't get the laptop to pick up the deesktop. What am I doing wrong?
  • Johnnie Peppers Feb 18, 2009
    Well I'm not sure if they are in the same work group. I looked around in the Network Settings section of the control panel and can't figure out how to even create a workgroup!
    I did however enable the files I wanted to be shared to be shared. Still my laptop is NOT seeing my Desktop. But My desktop sees my laptop and has it as part of its network. But When I try to access my laptop from the desktop I still get a message saying that "I do not have privileges to access this computer"
    What is going on here? I'm chain-smoking I'm so frustrated!
  • 137 Answers
Make sure both computers are on the same workgroup.. make sure you have the firewall settings to allow incoming connections to your shared files... make sure you have allowed acces to them in windows security panel..if you can access the media then you are almost there with the setting... fasted way is to right click on start choose explore then right click on drive or folder you want to share and then choose share from menu.. it will change your firewall and security settings so long as you have already turned off the windows advisor..
Posted on Feb 18, 2009
I just installed a Motorola SBG6580. I have it connected via Ethernet to my desktop (MS XP) and via wireless to one of my laptops (MS Vista). Both work well. However, I have been unable to connect my...
Try changing the authentication type to WEP/WPA/WPA etc. Might be your XP laptop doesn't support current authentication type. Thanks for joining us. Have a nice day.
Feb 24, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Our laptop won't connect to our network set up on our desktop home computer. The desktop is running Windows XP Home Edition V2002, and the laptop is running Windows Vista Home Premium V2006. When we try to...
if you have wireless acces point or 802.11 known as wi-fi,
there might be a problem in your laptop internet protocol, you laptop have an ip address already.
you can fix it by using your desktop, open your desktop go to control panel/network connection/status/
details.
copy the details information and put it to your laptop internet protocol. you can found it in network connection properties you can see Internet Protocol (tcp/ip) open it configure it manually. the last number of the ip address must bigger than the desktop. ex, 192.168.1.2 in desktop. the ip address of the laptop must be 192.168.1.3.
Feb 02, 2011 | Acer Computers & Internet
In your laptop Open Control Panel > Network internet > Network and Sharing Center > Set up new connection or network > match with setting in your PC > Finish. Try to reconnect.
Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Jun 01, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Trying to take a new wireless built in laptop, home to my current wireless network. The new laptop recognizes my home wireless network, but unable to connect to it. The laptop is a Dell studio 17 and...
If you are hardly doesn't connect even your wireless station is been detected why not try to set your settings manually in your wireless card.
This is when you are behind a router.
Goto Network and sharing center. Click on Manage Wireless Network. Click on Adapter properties. Click Internet Protocol version 4. Click properties, then set the ipaddress of your laptop it doesn't have to be identical to any of your existing connection, your subnet, default gateway. And also input your IP DNS.
May 18, 2009 | Computers & Internet
Toshiba Satellie P305D Wireless Connection Issue
If you are having an issue with your wireless at home, try changing the security settings on your router i.e changing the password, or encryption type.
Mar 16, 2009 | Computers & Internet
Netgear wireless router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
Network router printing issue
sure..you can put all the computers on the same workgroup, and form a network
we got fresh wireless drivers here too
Mar 17, 2008 | D-Link Wireless
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Problems with wireless and MS Vista
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers4.gif.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Oct 17, 2007 | Computers & Internet
Computers & Internet Logo
258 people viewed this question
David Payne
David Payne
