Question about Maytag Neptune MDE5500AY Electric Dryer
My frigidaire dryer is making a loud thud noise. I just replaced the belt on it. did not make this noise before.
  • 547 Answers
Roller wheels could be out of alingement or felt may need to be replaced
Posted on Feb 18, 2009
The dryer has a loud, high pitched squeek
Hello Robin, thank you for your post!
From the information you have provided your Frigidaire dryer is making a loud high pitched squeaking noise. This noise could be coming from your belt, motor, or spider arm. In order to find out which component might need to be replaced you would need to disassemble the dryer. We would recommend having a professional technician out to perform a proper repair. Improper disassembly of the dryer could result in personal injury or a problem with the dryer later in its life cycle. I hope that this information is helpful to you. -Matt
Feb 07, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My frigidaire fer231cas2 makes a horrible loud noise after its been running for 10 or so mins
There are rollers that the drum sits on. The roller surface or bearing can go bad causing the noise.
Aug 26, 2014 | Frigidaire Dryers
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
MAKING A
Hello
Some dryers use a motor driven drum.If there is a piece of belt missing this could cause a thud noise.
Also the drum rests in rollers,if a roller is missing or worn this could also be your noise.
Mar 21, 2010 | Maytag Dryers
We have a Frigidaire FER211AS2 dryer that started making a loud humming/roaring noise. Hubs replaced the bearing and drum belt. The noise isn't quite as bad but it still makes the same noise. What could it...
Check the alignment of the belt. Humming/roaring noise usually comes from a bearing, so your husband got it right to change the bearing and belt.
Now, he just needs to make sure that the belt is aligned right and the bearing is properly seated. Also check for rubbing marks around the travel area of the drum.
Oct 09, 2009 | Dryers
Beko DRCS68 condensor dryer is making loud vibration noises
hi there......when you replaced the drive belt you most likley disturbed the drum on its bearing seats (small plastic curved units) or indeed knocked 1 out altogeathrer...this would account for the loud bearing or metallic sound...it may also be the rear bearing these tend to eventually rund dry and fail..
regards Sir GalAHAD
Apr 17, 2009 | Frigidaire GLER331A Electric Dryer
Loud noise when dryer runs
Two items on two different dryers can make this noise. One is the belt tensioner pulley and the other is the bearing on a Frigidaire dryer.
Sep 27, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
176 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
