Question about Vocopro Audio Players & Recorders
No video output from vocopro da 3900k - Vocopro Audio Players & Recorders
Clean cd-g lens
You can purchase a cd cleaning kit with instructions to clean the laser lens.
Jul 08, 2012 | Vocopro DVD-Duet 80W CD / Dual Cassette /...
Hi, the cd player for this Sony system works fine with most of my cds. However, some of my older ones and burned ones don't produce any sound. The system recognizes the cd's cause I can skip tracks and see...
The only audio formats supported by the CMT-BX20i are "CD-DA and MP3". When DVDs were first getting started, they didn't have standardized audio and video formats. The burned videos are likely AC3. For both your old and burned DVDs, you can convert them on your computer with an audio video program like Nero or DVD Videosoft.
Mar 06, 2011 | Sony CMT-BX20i Shelf System
My speakers make a humming noise when i use the microphones
It's feedback! You need to move the speakers further away from them.
Feb 19, 2011 | Vocopro DVD-Duet 80W CD / Dual Cassette /...
It says no disc when you put in a CD.
Please clean your lens with lens cd cleaner and retry
Jan 13, 2011 | Vocopro DVD-Duet 80W CD / Dual Cassette /...
Error F61 Panasonic SA-AK240
am o combina muzicala marca panasonic modelul sa-ak240 si imi da o error f61,dupa ce o aprind la nici un minut imi da error f61 apoi se stinge.din ce cauza ma puteti ajuta??veri.nice78@yahoo.com astept un raspuns
Sep 08, 2010 | Audio Players & Recorders
CAN i purchase speakers for sanyo da 1000
Unless you want the same speakers for cosmetic reasons, you can get a pair of speakers from any Hi-Fi outlet. All you need to know is the max power output of the amp in watts for each channel, and the ohms it puts out. For instance if it says 8ohm 15 watts. You can get a speaker of 8ohms or higher, but not lower. And any speaker above 15 watts.
Actually you can get better quality sound from the speakers as the speakers they often put with these systems are rubbish in terms of hi-fi quality!
PS
Just had a look around the net and the output power in watts is just 8. Couldn't find the ohm rating but most are 8ohm. So any speaker higher than 8 watts will do the job.
Feb 10, 2010 | Sanyo Audio Players & Recorders
Won't play CDs; error message
vocopro gig star will not play cds.
Dec 30, 2009 | Philips MCM309R Shelf System
I dont know how to activate AUX on my Denon D-08
the only way i could figure out how to do it was to cycle through the modes with the "fuction" button on the remote control.Hope that helps.
Aug 17, 2009 | Vocopro DVDDUET-P2 Shelf System
It does not play all the CD , VCD , it s CD player has gone bad.
its happaning because of bad optical lence.
please replace it.
nuwan.
Jan 16, 2009 | Vocopro DVD-Duet 80W CD / Dual Cassette /...
Black and White video output
check your tv system,(PAL,NTSC etc.)same as your cd player,go to MENU and select both to ,AUTO.
Feb 05, 2007 | JVC MX-J900 CD Shelf System
52 people viewed this question
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
