Question about Dell A920 InkJet Printer
PRINTER NOT PRINTING - Dell A920 InkJet Printer
  • Anonymous Feb 22, 2009
    will print the first page the the second is fuzzy
  • 564 Answers
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 21, 2009
How do I stop my printer from printing memory clear report? so it can print.
Sign-in into printer (check the OM) and push "Stop Printing" or "Clean Printing queue" - depending on model.
Feb 19, 2015 | Canon Pixma Mx432 - Multifunction Fax /...
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Printer not printing in color
There is an option in the printer driver to print in color, B+W or greyscale - make sure it is set to color.
Apr 19, 2010 | HP LaserJet 2550n Printer
GREEN LIGHT KEEPS FLASHING ON MY PRINTER
Green light flashing means printer is in printing process. No problem. If you want to stop printing. delete printing job from printer properties or stop printing from status monitor.
Jul 23, 2009 | Epson Stylus C88 InkJet Photo Printer
Mac will not add printer
Hi, try to reset the print system as the apple article below:
SummaryWith Mac OS X 10.4, 10.5 or later, Printer Setup Utility includes a Reset Printing System feature, a troubleshooting function that you might want to use after you try all other printing troubleshooting stepsImportant: This feature should only be used as a "last resort" for troubleshooting a printing issue.
Products AffectedMac OS Printing/Fax (any version)
What does Reset Printing System do?
  • Deletes all printer queues and jobs.
  • Resets all printer settings to their default by deleting configuration files.
  • Performs a permissions check on the /tmp directory.
Any devices that previously appeared in your Printer List and Fax List will need to be added again after resetting the printing system.
Resetting the printing system in Mac OS X 10.5.x
  1. To use the Reset Printing System feature in Mac OS X 10.5.x, follow these steps:
  2. Choose System Preferences from the Apple menu.
  3. Choose Print & Fax from the View menu.
  4. Control-click on list of printers on the left side of the window, then choose "Reset printing system" from the contextual menu. If you don't see a list of printers, Control-click on the text "Click + to add a printer or fax" and select "Reset printing system..."
    As an alternative, if you currently have one or more printers listed, you can Option-click the "-" (Remove printer) button.
Resetting the printing system in Mac OS X 10.4.xTo use the Reset Printing System feature in Mac OS X 10.4.x, follow these steps:
  1. In the Finder, choose Utilities from the Go menu.
  2. Open Printer Setup Utility.
  3. From the Printer Setup Utility menu, choose Reset Printing System.
  4. Click Reset.
Additional InformationTip: If Printer Setup Utility won't open at all (possibly due to your printing issue), you can try to access the Reset Printing System feature directly by holding down the Option key while opening Printer Setup Utility.
Mar 14, 2009 | Apple Computers & Internet
Printer problem
The HP DeskJet printer will not print, it prints only partial pages, or produces ... remove the scanner, remove the printer driver, and reinstall the printer driver with all programs and ... the paper out of the printer after printing is finished. If one, or ... the kicker feet on your printer are broken, have the printer serviced. ... In tray only when the printer is not printing. Adding paper while printing can cause paper jams. Do ...
Jan 17, 2009 | Office Equipment & Supplies
HP C4200 Printing both sides
Some printers automatically print on both sides of a page (automatic duplex printing); other printers allow you to manually reinsert pages to print the second side (manual duplex printing); and some printers do not support duplex printing at all. To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box.
To find out whether your printer supports duplex printingThe options in the Print dialog box can vary depending on your printer options and configuration.
You can use the following clues to determine whether a specific printer supports duplex printing:
  • Check your printer manual or consult your printer manufacturer.
  • Click the tabs in the Print dialog box and review the options. If options such as print on both sides of the paper, duplex printing, or two-sided printing appear on any of the tabs, the printer probably supports automatic duplex printing.
Notes
  • If you are printing to a combination copy machine and printer, and the copy machine supports two-sided copying, it probably supports automatic duplex printing.
  • If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
To manually set up a printer to print to both sides of a sheet of paperWith some printers, you can use the Manual duplex check box under Printer in the Print dialog box. Word will print all of the pages that appear on one side of the paper and then prompt you to turn the stack over and feed the pages into the printer again.
You can also use the following procedure to set up your printer for manual duplex printing:
  1. On the File menu, click Print.
  2. In the lower-left corner of the Print dialog box, in the Print box, click Odd pages.
  3. Click OK.
  4. After the odd pages are printed, flip the stack of pages over, and then in the Print dialog box, click Even pages.
  5. Click OK.
Note Depending on the printer model, you might have to turn and reorder the pages to print the other side of the stack.
Sep 08, 2008 | Office Equipment & Supplies
Randomly printer stops printing - need switch off and on to restart printing
Sounds like you are just beginning to have problems with the paper feeding. Try cleaning the roller or applying rubber cement per my other post on the paper feed topic.
Apr 12, 2008 | Samsung ML 1210 Laser Printer
Printer
try printing a test page. Make sure you have the right driver for your printer. Make sure all connection are secure and tight.
Mar 27, 2008 | Compaq Inkjet IJ650 Printer
Dell A920 InkJet Printer Logo
126 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
