Question about Toshiba Satellite Pro M300-S1002X Notebook
"Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
This is driving me crazy, and I'm almost giving up on my Toshiba.... I have tried a New battery and a New AC Adapter already... it got fixed for a few days, then the problem comes again.
I've noticed that if my battery is low, like 20% or less, connecting AC adapter results in 10 seconds or so of "plugged in, charging", and then, not charging.  I disconnect and connect, same results.  Remove battery and install again, it works for a little while, then it fails again. If I close the laptop, it will charge battery. If I open and use an application,  for example, Internet Explorer, as soon as the application opens, battery charging indicator turns off, and "Plugged in, not charging" comes again. So the thing is I'm not able to use my computer for long periods of time, because it needs to be closed in order to recharge the battery. Any ideas???
my toshiba satellite pro m300 charges only when i shut it down, or when its closed - on standby- but as soon as the systems boots up the light turns off and it stops charging... after its battery time it does die... so i know its definitely not charging
  • xxsalxx Feb 26, 2009
    it was a motherboard problem for me... likely the same thing... i really don't know ANYThing abt computer problems, but the guy who fixed mine said something about BIOS and changed my motherboard... lol
  • nixon_mendoz May 11, 2010
    how to dismantle a toshiba satellite m300? can someone please help me because i need to check the power socket. thanks
  • Toshiba Master
  • 32,281 Answers
It sounds like the power socket on the laptop is faulty and needs replacing or resoldering. To check this, power up the latop with the power adapter, wriggle the plug in the power socket and check if the battery charge indicator flicks on and off indicating charging and not charging. If it indicator flicks on and off then you have a faulty power socket.
This can be repaired but required the laptop to be completely dismantled to access the power connector.
Posted on Feb 18, 2009
  • Chris Hingee
    Chris Hingee Feb 19, 2009
    Does your new adapter match the voltage rating that is printed on the label on the bottom of the laptop and does the current rating match or higher than what is stated on the laptop label?
MY TOSHIBA SATELLITE A135 S4527 HAS NO NETWORK DRIVERS ON WINDOW XP HOW TO DOWNLOAD THEM?
You can download any/allthe Windows XP or Vista device drivers for your model laptop from the ToshibaWEB site from their download page. Make sure you enter the model of your laptopso you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Dec 08, 2010 | Toshiba Satellite A135-S4527 Notebook
In windows vista home premium I can't see my removable media (CD, sd, usb drives) using explorer, but if I enter the drive letter (d:) in the address bar, it finds it. Unfortunately, some apps just don't...
Have you tried to upgrade you operating system? I suggest you create another account on you computer, and log in the new account an try. Feel free to visit DigitalSupportTech for getting help.
Aug 31, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba A135-S4527 will not automatically shut down
If you truly believe the problem happened right after installing the new mouse, then you should start by uninstalling the software for it. Go to Control Panel -> Software -> Uninstall. If this fails, you can use the System Restore utility to rollback the Windows registry to a time before you first installed the new mouse software. Have you tried to unplug the mouse and not use it, atleast on the attempted shutdown process?
Mar 22, 2009 | Toshiba Satellite A135-S4527 Notebook
Invalid product key Windows Vista Home Premium with Toshiba
this could be because someone took the license key that was origionally installed on your computer, did you lent it out? The same product key can not be activated on 2 computers unless it has multiple licenses. I had this problem, but i simply called microsoft and they shut down the other product key and gave me a new one for free.
Feb 18, 2009 | Toshiba Satellite A135-S4527 Notebook
I started having the same problem and worse mine would shut off without warning either from the battery running down or even just plugged in without a battery.
I thought It might be overheating so I got a can of air and cleaned all of the vents...and downloaded core temp to monitor the cpu temp @ http://www.alcpu.com/CoreTemp/. Same problem shut down and no charging even though it was running cool.
Finally I started changing settings and it seems to be working and charging just fine.
Here's the answer:
1. Set your power scheme to balanced
2. Open Toshiba Assistant from start
3. In Toshiba Assistant open CPU tab and set to low power.
4. When asked "restart now?" say no and shut it down using the start menu.
When you start it back up you will see the change.
Changing either one of these settings brings the problems back. I can't explain it.
I HOPE IT WORKS FOR YOU!
I just can't afford another laptop right now.
P.S. even at low power my system works fine...It's a little slower @ start-up but otherwise good.
Sep 30, 2008 | Toshiba Satellite A135-S4527 Notebook
Looking for driver
I have downgraded my toshiba satellite A135-S4527 from windows vista to windows xp and since then i have not gotten the lan and wireless drivers. Could you pls help me get it
Sep 05, 2008 | Toshiba Satellite A135-S2276 Notebook
Drivers for Toshiba Satellite A135-S4527
type this in your search engine ....
toshiba support-content list
some tittles of exactly what you typed in will display...
click on one and youll be at the download page...
just been there.I'd type the page in for u but its very long as youll see when u get there.
Apr 12, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba a135-s4527
I did a quick google and found this. Hope they help.
http://rapidshare.com/files/31883631/Satellite-A135-S4427_xp_drivers.zip
Jan 06, 2008 | Toshiba Satellite A135-S4427...
Toshiba a135-s4527
If you are talking about the software that lets you watch a DVD you will not get that as part of XP. You must purchase a DVD player program. It is not the driver that lets you do that.
If the system lets you see the DVD drive at all the driver is correct.
Nov 17, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite Pro M300-S1002X Notebook Logo
1,067 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
