Question about HP Photosmart C5280 Printer
I have an HP Photosmart C5280 connected to my wireless network. It suddenly stopped printing in the middle of a job, giving no error message. Now all attempts to reset and restart are ineffective; it either says it's printing when it's not, or says the printer is busy. Help!
  • 1 more comment
  • daveburkey Feb 18, 2009
    Now the printer says it is busy every time a job is sent to it. All jobs have been deleted, everything has been restarted, cables reconnected, etc. I don't know where the drivers are on a Mac or how to uninstall and reinstall, etc. It did just stop in the middle of a job and then start doing this.
    I reinstalled the software and got the same results. The printer is available and ready, but when a job is sent, it then says it's busy, and nothing happens. I clear the job every time and start over, with the same outcome.
  • daveburkey Feb 19, 2009
    I have tried reinstalling drivers, etc. and it doesn't work. The last couple of steps always fail- something called the HPIO Trap Monitor always quits unexpectedly, and then at the very last step, my printer can't be found. When I write it in, it shows up, I click on it, and then it disappears again. I have no idea what the problem is, since, as I mentioned, we have successfully printed from this printer on both our laptops. It just started doing this out of the blue!
  • 544 Answers
Thank you for using Fixya.com website.
here i post some instruction you can follow to reinstall your unit..
hope it will help you to solved your problem..
To use all functions of the HP product, please connect via one of the following supported connection types. Additional supported connection types, including network compatibility information, are listed on the product box, in the supplied documentation, and on the HP Web site.
  • USB
  • Ethernet
  • WiFi
Step one: Connect the product to the router
If the product is USB compatible, connect it directly to the USB port of the wireless router on the functional network. The following printer models are not network compatible or compatible with wireless routers.
  • HP All-in-One: PSC 1000, 1100, 1200, 1300 and 1400 series, Officejet 4100, 4200, 5550, and 5600 series
  • HP Deskjet: Deskjet 3300, 3400, 3500, 3600, 3700, and 3800 series
  • HP Photosmart: Photosmart 145 and 245 series
Step two: Download and install the print drivers
If the product software CD that shipped in the box is available, skip this step and continue with 'Step three: Add the product.'
  1. Click here to go to the HP Software and Driver Downloads page.
  2. Type the product model name in the For Product text box, press Enter , and then select the product model number from the list that appears on the computer.
  3. Click the operating system installed on your computer.
  4. In the Software section, click Full Feature Software and Drivers .
  5. Click Download only .
  6. Double-click the file after the download is finished to start the installer.
  1. Open Mac HD .
  2. Open the Applications folder.
  3. Open the Utilities folder.
  4. Open the Printer Setup Utility .
  5. Click Add .
  6. Highlight the printer with the connection type Rendezvous or Bonjour .
  7. Click Add .
Posted on Feb 18, 2009
  • Mark Milan silaran
    Mark Milan silaran Feb 18, 2009
    hello their again..
    in your situation we already try our best to fix on it.
    but i think and sure the problem is not in the software anymore it is on the hardware.
    so i prefer to you to go for a computer shop and ask for technician assistance about this matter..
    we know it will cost you for payment but it is much better than to buy again with a higher value..
    hope you will follow my advice..
    thanks..
    Mark Milan silaran Feb 19, 2009
    hi,
    please check the conection of your wireless to computer and to your lan.
    or go to printer section and cancel all the pending documents after that reset and print again choose the default printer..
    thanks,
    Guru:
  • 832 Answers
Hello there! thanks for using Fixya.com!
I suggest that close all the connections that you have. Disconnect the wireless connections from your laptop or pc to the printer and then start all over to connect the printer to the pc again.
Or simply, check the access point if its working properly. Switch on/off the printer, and check the printer settings as well.
Or you may do this to troubleshoot your device:
The IP address, subnet mask, and default gateway addresses for the computer are sometimes needed when setting up a network. Viewing the IP address, subnet mask, and default gateway addresses
  1. Click Start .
  2. Click Run . The Run dialog box displays.
  3. In the Open: text box, type command and then click OK .
  4. At the command prompt, type ipconfig and then press Enter . The network settings for the computer display, including the IP address, subnet mask, and default gateway
The wireless adapter settings on a computer are needed when setting up a wireless network. View the wireless adapter settings
  1. Open the Control Panel .
    • Category view : Click Start and then click Control Panel .
    • Classic view : Click Start , click Settings , and then click Control Panel .
  2. Double-click Network Connections .
  3. Right-click the wireless network connection and then click Properties .
  4. Click the Wireless Networks tab.
  5. Select the wireless network and then click Properties . The wireless information displays, including the Network Name (SSID) and network key. NOTE: The network key is case sensitive and might be longer than the box can display. Place the cursor in the box and use the right arrow key to view all of the characters
This document gives general instructions for printing from a Bluetooth-enabled device. Refer to the documentation that came with the Bluetooth-enabled device for more detailed information. NOTE: The printer can establish a Bluetooth wireless connection with only one device at a time. If the printer is busy with a Bluetooth wireless connection, the printer ignores any other device that tries to establish a connection. The device must wait until the original connection is closed before it can establish a new connection. NOTE: The HP all-in-one does not support Bluetooth Hardcopy Cable Replacement Profile (HCRP) - Bluetooth devices can send images for printing only. Printing from a camera phone There are two possible ways for printing photos from a camera phone; printing from the imaging application or from a “Print” application. Printing from an imaging application Follow these instructions to print photos from an imaging application.
  1. From the imaging application, select Send via Bluetooth .
  2. The phone searches for Bluetooth devices. After the phone locates Bluetooth devices, select the appropriate printer.
  3. If prompted for a Passkey, enter it.
Printing from a printing application The following method can be used if the camera phone has a printing application. (The Print application software can be downloaded from the phone manufacturer's Web site.)
  1. Press the Menu button.
  2. Select the print application.
  3. Select the item to print.
  4. Either select Find Printer or Accept the printer selected.
Printing from a digital camera NOTE: These are general instructions. Refer to the camera documentation for detailed instructions.
  1. Place the camera in Play/Review mode and scroll until the desired picture is displayed on the screen.
  2. Press the Menu button and select Transmit .
  3. A list of Bluetooth devices displays. Select the desired printing device and press OK .
Printing from a PDA NOTE: These are general instructions. Refer to the camera documentation for detailed instructions.
  1. From the desired application, select Send or Print .
  2. A list of Bluetooth devices displays. Select the appropriate printing device.
  3. If prompted to enter a Passkey, enter the printer's Passkey, then press OK .
Printing from an HP iPAQ Pocket PC Use one of the following methods to print from an HP iPAQ Pocket PC with HP Image Zone.
  1. Tap HP Image Zone .
  2. Select the desired image to print.
  3. Tap File , then Print . Figure 1: Tapping File, then Print
I hope that I helped you somehow. Thanks again. And pls don't forget to rate me! have a nice day!
  • 2 more comments
  • Dennis Jambalos
    Dennis Jambalos Feb 18, 2009
    hi again!
    In addition, if you have an MAC os, pls follow this guide.
    Mac OS: Connecting to the USB Port on a Wireless Router
    In general, HP products that support networking and/or optional JetDirect print servers print when connected to the USB port of a wireless router, such as the Apple Airport Express and Extreme Base Stations.
    NOTE:
    Connecting to the USB port on a wireless router provides print functions only. Additional functions of the product, such as scanning or card slots, are not available.
    • USB
    • Ethernet
    • WiFi
    1. Open Mac HD .
    5. Click Add .
    7. Click Add .
  • Dennis Jambalos
    hi again...
    if you have an MAC os, pls refer to this to help you more! thanks!
    NOTE:
    • USB
    • Ethernet
    • WiFi
    1. Open Mac HD .
    5. Click Add .
    7. Click Add .
  • Dennis Jambalos
    hi again!
    Did you check the printer screen? what does it say? pls check if it is online/offline? And try to go to your printer settings just to see what does it say.
    Regards!
  • Dennis Jambalos
    Dennis Jambalos Feb 19, 2009
    Hello again!! still there??
    I have this another solution:
    1. Go to the Printer itself.
    2. Select network settings.
    3. Assign an IP Address like 192.168.10.2
    4.Then, go to your laptop.
    5. Go to Print Option, select add printer and then create a port option and select on which port then select TCIP port and enter your IP address.
    6. Restart the laptop, and try to print a test page only.
    Thanks and Cheers!
    hope it helps.
  • 495 Answers
Please visit this link to know complete install and uninstall procedures
h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=29386&lc=en&dlc=en&cc=hu&lang=en&product=3204464
  • HP Master
  • 19,396 Answers
Unplug the printer from power and restart computers that are using this printer on the network, then plug back the printer and test it.
If still no luck ping the printer IP to check if printer is on the network, if it is not on the network, reinstall the printer on network.
Check also the printer cue on computer and empty it.
  • Ginko
    Ginko Feb 18, 2009
    Then the printer buffer has a problem.
    Unplug printer from power for ten minutes to reset everything (turning off is not enough) and restart the computer.
    If still does not work after restart you need to test the printer as a local printer (connected with USB).
    If the printer does not even work when connected to USB, then the printer is faulty.
    Test it out.
    Genius:
  • 1,847 Answers
Reinstall the printer software again and try.
    Genius:
  • 1,550 Answers
You uninstall the driver file from pc and reinstall it with latest updates and try printing .
  • SAM ANDERSON Feb 18, 2009
    You follow the steps from the link below
    The steps are for MAC os .
    Click this link to direct to hp website for procedure to set up
    Hope this helps
    If you still have problem feel free to ask
    Follow the steps to remove and re-add the printer to the list
    1. On the upper left corner of the computer desktop, click the Apple menu icon (
      ), and then click System Preferences
      on the drop-down menu.
    2. Click
      Print & Fax
      , select the product to remove in the
      Printers
      list, and then click the
      minus
      button (-) to delete it.
    3. Disconnect the USB cable from the product.
    4. Close all open windows, and then restart the computer.
    5. Click the Apple menu icon (
    6. Click
      Print & Fax
      to open the printers folder.
    7. Reconnect the USB cable to the product.
    8. If the product is not automatically added, click the plus sign (
    9. Select the product to add, and then click the
      Add
      button. After a few seconds, the product displays in the
      Printers
      list.
    10. Try the print job again.
    Source http://h10025.www1.hp.com/ewfrf/wc/docum...
HP Photosmart C5280 No computer connection
mail or call to the technicale support team of hp for that problem and get the folloups from them every day, i cant say much more becouse its realated to mac and for mac there is too less data available on hp sites.
Jun 13, 2012 | HP Photosmart C5280 Printer
I put in new ink an it is giving me a OXC18a0106 error
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and
go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Photosmart 3210 Printer
Error message when trying to copy a document: Paper size detected is not supported. Job cancelled.
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
Oct 26, 2010 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart All in one Printer Wireless printing problem
try reset printer network settings and test again, and check for any high power electronics, nearby printer. because the magnectic fied is a wireless wall that reduces wireless signal.
Jan 03, 2010 | Xerox DocuColor 12 Printer
Need to print a half-fold card envelope with HP Photosmart C4480
I also contacted HP and they directed me to a workaround which I have not implemented yet!
Mar 07, 2009 | HP Photosmart C5280 InkJet Printer
Out of Paper
Your welcome. So, fix ya?
Jan 30, 2009 | HP Photosmart C5280 InkJet Printer
Error msg status 1
sounds like a communication error, are you wireless?
try connecting direct.
Feb 05, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C5280 Printer Logo
432 people viewed this question
Ben Johnson
