Question about Panasonic KX-TG1033S Cordless Phone
Rigid insulation my panasonic has rigid insulation flowing out the back.
  • 514 Answers
Return for warranty
Posted on Feb 22, 2009
RIGID R4040 replaced the armature(brushes and bearings too, now It won't turn on. It has power, laser works, brushes are wired, didn't disconnect the stater. what the heck am I missing?
Either something about the motor is dud or power isn't reaching it.
I suggest you dust off your trusty multimeter and check the circuit/motor for continuity. There could be a thermal fuse that needs replacing.
If there is one it is likely to be covered in insulation and clamped to the motor or very close to it.
Dec 22, 2017 | Saws
What is the size of the gas line piping on the out door unit of a elite elegance split unit
You need size of pipe , length of run , input of btu.s you need all this before you can size pipe
Jan 18, 2017 | Heating & Cooling
Thermal Breaking Window
something wrong with this advertisement
proof is , heat up a piece of aluminium and see how long and how close your hand is to the heated section before you get burnt
then wrap a piece of fiberglass around the aluminium and heat it and see you get burnt at all
aluminium is used in all radiator fins for the heat transfer properties
Dec 22, 2016 | The Watches
How do I take stand off tv
Usually you would unscrew the bolts from tv to the stand (for rigid type).
Non-rigid type made have a release button and lift up.
Be carefully to protect the tv from damage, laying it side and covering screen would help from my experience.
Feb 28, 2015 | Panasonic Televison & Video
I am fixing a closet in my home. It is part of an exterior wall and creates a lot of coldness in the house. How can I insulate this wall better? My kid is freezing at night she says. <a href
If you have enough room behind the stud wall install 1" rigid foam tape seams and then use the thickest possible roxsul insulation to fill the studs. Or axe the foam and install 6mil plastic on warm side of the wall after insulating tape all seams when done.
Jan 30, 2015 | Cam Spray Pressure Washer Foamer...
My dryer says to check the lint trap
A sensor is saying ". . .airflow is blocked. . " Blockage could be the air filter or trap or ducts within the dryer or the 4" flex duct attached to the back. First, remove the 4" duct and see if there is good air flow with dryer running. If so, ream the duct all the way to the outside. If not, disassemble dryer to get to internal rigid ducting and blower. Also, make sure the blower wheel is not broken and can rotate freely.
Oct 17, 2014 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Very low sprayer head flow
You can help to isolate the problem by checking the flow through the angle stops under the sink. Best way to do this is to first have flexible hoses, most likely 3/8" by 1/2". These flexible hoses can easily replace rigid piping from the angle stops to the sink. Turn the angle stops off, then unscrew the hoses/piping from the under the faucet. Aim hose into bucket and turn angle stop back on. If flow is still strong, then replace faucet. If flow is weak, call a plumber.
Mar 16, 2010 | Blanco Classic Single Handle Faucet with...
How hot is the Vent temp of my new Duet?
It's not the temperature of the air that is the problem. The air is seldom over 160 Deg F. If you have a vent fire the piping needs to last long enough without melting to starve the fire of oxygen in the hopes of extinguishing. Rigid aluminum piping is best suited for this, Rigid flexible is next. The tin foil and white plastic offer little resistance to melting if a fire should begin. The melting would allow the fire to replenish oxygen and support the burning process. The main caution here is to keep your dryer and vent clean...at least annually.
If the duct inside your wall is rigid metal all the way from the dryer to the house exit you need to do nothing to it . Replace the vent between the dryer and the wall with rigid metal 4" piping or hard flexible aluminum piping. If the duct inside your wall is either of the least effective types you need a new run of vent for the dryer to avoid a fire.
You can't use white plastic or flimsy flexible aluminum that feels like aluminum foil when you touch it.
Sep 10, 2009 | Whirlpool Dryers
GE Refrigerators - Water dispenser not working ? I
remove front grill then disconnect the water line at the quick connector. Place line on right side into container and push lever for water. If no water flows the problem is a solenoid on the left side of the back of refrig behind lower panel. If water flows into container the problem is related to freezing of the water line in the freezer door. GE fix is a $500 plus door replacement. Thaw from back of door behind the dispenser with hair dryer (do not get plastic too hot). Cheap fix is to insulate back of door with insulation such as a foam sleeping bag mat or the foil and bubble wrap type of ducy insulation
Nov 16, 2008 | Refrigerators
Maytag Performa dryer venting
You are always better off using steel on these kinds of conversions and do not worry about how hot it gets,..Aluminum will get hot too. Steel is more rigid and less likely to dimple in while installing or hooking up the external vent system... Hope this helps..
Sep 01, 2008 | Dryers
Panasonic KX-TG1033S Cordless Phone Logo
29 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
