Question about Riso RZ220 Duplicator
I cant return the drum for my machine risograph what shall i do
  • 318 Answers
This meens your Riso's timing is out.Put your drum in home possition by rotating it untill it locked.Slide the drum back into the machine.If this doesnt help you will have to realign the machine to the home possition.
Switch the machine off.At the back of the drum there is a gear that have to align with the Main drive gear of the machine.Turn the main drive gear untill the guides of the gear matches the drum' gear.But remeber that gear doent move easely.
Try to slide the drum back again.
Be carefull not to cut yourself with the inner plates of the machine
Posted on Feb 18, 2009
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
I have a Riso CR1610 and one of the drums leaks like the devil whenever I use it. Any ideas?
your drum seals are worn out you need to call for your technician to replace the seal or replace the drum unit.
Apr 22, 2010 | Riso RZ220 Duplicator
My Risograph CR1610EP will not make a master. I can hear it remove the old master. The JAM indicator comes on and the number 2 in the center of the drum. There is no master (old or new) on the drum.
We had the same problem in that once master was done, it did not print. We tried this solution.
Machine must be off. Top right hand corner the and - buttons with arrows on (to align your print either left or right) press these down simultaneously. While holding them switch machine on.
A number 203 will appear on your screen.
Release hold on buttons Press 101 on number board you will hear machine inking master. Allow it to run until complete.
Hope this helps.
Apr 04, 2010 | Riso Office Equipment & Supplies
Risograph cylander is jammed. It is ajar but won't come out or go in. I think the film did not complete it's loading to make a master. Parts are not where they should be. How can I get the cylander back in...
The drum cylinder of any risograph has a locking position. The drum position should be locked on before puting it back on the machine. After you confirmed the proper position and tried to putting it back and still no progress you do the following.
1. Removed the drum unit from its holder.
2. Use flash light and check inside of the machine. Check a shsft in the middle part of the machine where the drum put on.
Check the position of this shaft and the position of the drum hole where this shaft will put on.
3. Try to rotate this shaft according to the position of the hole of the drum then try to return the drum and put it back again.
4. If the drum won.t go in just half way, removed the drum and check the pressure roller position, if the roller are in highest position This roller in under the drum. If you see it blocking the drum removed the back cover and released the hook lever from pressure lever. You can see this by moving the roller and you will noticed its position,
Jan 07, 2010 | Office Equipment & Supplies
No drum in machine and can't pull out tray to put one in.
Look at your drum. Is it locked in it's home position?.. If it is then look into the machine.. Take a pair of needle nose pliers reach in and insert the into the female side of the cam and manually turn it so it matches the drum.. (with the machine off) Turn on the machine again and try to re-insert the drum. Look carefully at that cam in there.. It only can go one way.. It appears that you could turn it just 180 degrees and it would work.. but it won't fit.. This should solve the problem.. once the drum is in the machine it will find position b on it's own..
Apr 20, 2009 | Riso Office Equipment & Supplies
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
554 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
