Question about Fuji FinePix S5000 Digital Camera
I bought my FUJIFILM S5000 camera from USA, used it for about 5 years. Now it won't take pictures. Seems the trouble is with its driver software. Now I am in India. Can you suggest anyone in South India who can provide the Driver Software?
  • dnbnetcom Feb 21, 2009
    So does anyone know which part is the CCD module? I have a good camera that is cosmetically UGLY and a prestine one with the bad CCD board I would love to give my camera a face lift without tearing everyything out? I was looking for a technical exploded view when I found this site? Thanks Don in SF, CA USA
  • Anonymous Mar 23, 2009
    my LCD screen is red when l take a photo it becomes black
    President:
  • 1,223 Answers
It is not a driver problem bro if it is not showing anything i mean u take pic and it is black or dis colored its a CCD failure u cant help it go to fuji repair centre and bang on their head its a hardware fault 1000's are facing
Posted on Feb 20, 2009
  • Shoaib Rais
    Shoaib Rais May 31, 2009
    CCD FAILURE !
    CALL Fujifilm they will do it FREE it is a known problem in thousands
    of camera i got my S5000 with same problem repaired FREE from FUJI just
    call them
    BAD CCD
    RATE ME WELL !
Why does my fujifilm finepix s5000 camera say memory card is full when it is empty ?
RAW format uses enormous file sizes. Smaller memory sticks will be used up with just one single picture when using the RAW format. You're confirmed this when you said it only happens when you use RAW format. You need to use a larger memory stick, if you want to use the RAW format.
Jul 12, 2014 | Fujifilm Finepix S5000 Digital Camera In...
I have a FujiFilm S5000 and since 2 weeks the sensor seems not to be able to adjust when trying to take a picture in sunny condition. The screen shows white and pink colour with horizontal lines. I turn...
Actually it's not the sensor it's the LCD screen. I would say in the last two weeks the camera didn't change but the environment it is being used in has and is causing the camera to overheat.
Diagram
Temperature
Diagram
Keeping the camera within these perimeters should solve your problem.
Jan 18, 2011 | Fuji FinePix S5000 Digital Camera
Fujifilm S5000 !hand error
It it in normal shooting mode? The hand means the shutter speed is too slow to hand hold the camera.
Jul 24, 2009 | Fuji FinePix S5000 Digital Camera
Fuji Fine Pix s5000-Horizontal lines with purple coloring mixed
not a software issue it is
CCD FAILURE !
CALL Fujifilm they will do it FREE it is a known problem in thousands of camera i got my S5000 with same problem repaired FREE from FUJI just call them
BAD CCD
RATE ME WELL !
May 27, 2009 | Fuji FinePix S5000 Digital Camera
CCD FAILURE
CALL FUJI for FREE repairs u are eligible i got mine repaired free it is a known problem
Regards
Zohail
May 25, 2009 | Fuji FinePix S5000 Digital Camera
I have a fujifilm finepix S5000 when camera is turned on it just shows a white screen. Cant take pictures, movies, nuffin works. Can u help, please.
if u see white screen and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
http://www.imaging-resource.com/badccds.html
for support in usa or select different region www.fujifilm.com
http://www.fujifilmusa.com/support/ServiceSupportContact.do
Apr 09, 2009 | Fuji FinePix S5100 Digital Camera
Software
This may be what you need:
http://www.fujifilm.com/products/digital/download/02/ist.html
Either way, that's the FujiFilm website, so it should be somewhere. All I found was updates for different versions (i admit i didn't spend too much time looking).
www.fujifilm.com is the original website, so I recommend you go the go, select country, select camera, etc instead of typing in the link above (it will probably be dead.....it always happens).
Jun 19, 2008 | Fuji FinePix S5000 Digital Camera
S5000 ccd replacement
You need ot send it back to the address in this articale and they will fix for free. It is the same problem with mine. You can also call and they will tell you this, Hope this helps you.
Service Advisory to Owners of
the FinePix A303, F410, and
F700 Digital Cameras
spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif Thank you for your patronage of Fujifilm FinePix digital cameras.
FUJI PHOTO FILM U.S.A., INC. announces that some of the FinePix A303, F410, and F700 digital camera models may develop a problem with the CCD imaging sensor. However, the problem affects a limited number of units and may not occur in all cameras.
The symptoms are captured images that appear completely black, have a purplish cast or multi- colored distortions. These symptoms would be seen on the camera LCD monitor when the camera is in the shooting mode or during playback. A limited number of these models will have these problems. The following list of serial numbers and model names may be affected:
Model Serial Number Range FinePix A303 3JA4****∼3JA5**** FinePix F410 32A1**** 32A6****∼32A7**** 32A9**** FinePix F700 33A0**** 34A1****
Serial numbers are found on the bottom of the cameras
If your camera serial number is on the list and experiences the symptoms described above and have no other additional damage/malfunction, FUJI PHOTO FILM U.S.A., INC. will repair your camera at no charge, even if your standard one-year limited warranty has expired. If your camera is beyond the standard one year, limited warranty period, you will receive a written estimate for any additional damages or malfunctions not listed in this Service Advisory.
This announcement is issued by FUJI PHOTO FILM U.S.A., INC. and is limited to only those Fujifilm products imported to the U.S.A. by FUJI PHOTO FILM U.S.A., INC. and sold by FUJI PHOTO FILM U.S.A., INC. to authorized dealers.
IF SERVICE IS NEEDED:
Package the camera carefully using ample padded material to prevent damage in transit. Include your name, address and phone number with the shipment as well as a general description of the problem. Keep a record of the camera's serial number and shipment tracking number. Ship your camera to the Fuji Service Center noted below:
Fuji Photo Film U.S.A., Inc.
1100 King George Post Rd.
Edison, NJ 08837
Attn: Camera Repair Dept./CCD Advisory
Jun 01, 2008 | Fuji FinePix S5000 Digital Camera
Battery compartment door is ok but the teeth on the camera are broken. is this repairable?
You would have to replace the inner housing to replace the latches.
Fuji USA might have a fixed rate for this, here is the link to the support page for the S5000: FujiFilm
Mar 24, 2008 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
266 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
