Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Problem with d52w20
Power light blinks on and off three times after several cyles of this it will turn on and run fine
  • Anonymous Feb 18, 2009
    i had the same problem with the power light blinking 3 times then turns back off and no picture ever came up, now after 3 months of this it doesnt come on at all it used to come on after a few trys but now all is dead, just 3 blinks and back off again,
  • dsteele1 Feb 19, 2009
    Same exact issue. Every repair dude in may area is trying to charge about $400 and up. Alot of people have solutions on this site about the issue as far as replacing cp150 or flybacks but i'm no electrician and dont know how to solder. Good luck tho, i'm still trying myself.
  • RCA Master
  • 5,138 Answers
On the Deflection board there is 3 capacitors cp114,120,150 if any of them is puffed up on top replace all 3 capacitors cp150 2200uf 16 other 2 are 220uf 35v theywill be green with gold writing on them. Resolder all pinns on FBT also.flyback transfomer.
Posted on Feb 19, 2009
Describe your D52W20 52 in. Rear Projection HDTV-Ready Television Problem the tv will not turn on the power light will blink three times then shut off
That could be caused by the CP150, CP120 and CP114 capacitors on the deflection board. Very famous issue. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Aug 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 Does not power on- what to check for?
Hi, if the capacitor has bulged out then its likely to have taken out a fuse on the board, they are not obvious to find as they surface mount them, they look like resistors, often a white body with a number on it eg, 5 for 5amps. With the power off, check around the componets for open resistance, set your meter at 10 or 100 ohms, analogue meters are better than digital for this analysis. Watch out for capacitance as ther could be several hundred volts stored in the circuit.
Mar 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA D52W20 with chassis ATC 221 that no longer works. When plugged in, the green power light blinks twice and then goes out. When the power button is pushed the light blinks twice, then about 4...
The tv is going into protection shutdown. It will try to power up three times, but each time it tries, the microprocessor recognizes an overvoltage, or overcurrent draw, and after three attempts it will place the unit into protection shutdown. There can be many causes of this, but the most likely one is that there is a short circuit in the high voltage circuits. You probably have a shorted flyback and associated components.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20
it should if you can get one most have been on back order. the board with the ihvt on it is the one to replace
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I'm having a problem with my Panasonic PT-53wx52
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Oct 30, 2008 | Panasonic PT-53WX52 53" Rear Projection...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
113 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
