Question about Philips 43PP9202 43" Rear Projection Television
Turn on problem
TV turns on cold fine runs good after that.. if you have tv on, and turn it off you have to wait atleast 5 min for it to come back on,if you try to turn on too early it clicks on then clicks back off... help appreciated not sure (replaced IC's and 2200mf caps at back of standby pwr supply)
    Problem Solver:
  • 15 Answers
If you tap it on the back of tv and stars on/off that meens there is cold soldering on the board.You need to resolder the board especially solder all ICs pins.Make sure no shorts you have made after soldering.
Posted on Apr 16, 2009
Panasonic pt52lcx15 TV. Recently, after approximately 5 min. The TV turns off. Is this some sort of power supply issue? Or, something else?
Try this.
Unplug the tv. take off the back panel. vacuum or blow out the dust with a can of compressed air (@ $3 at Staples). A lot of the projection tvs had a thermal sensor which would turn the tv off if it got to hot.
That is also a good time to clean the lenses. Be careful not to move them out of alignment. My tv worked like new after I did those things.
Jun 10, 2015 | Panasonic Televison & Video
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Help! no sound on my tv!
check all the leads and wires, especially the scart lead, and give them a little push, if this doesnt work (which it should) then unplug the tv from the mains, wait 5 mins, plug back in, wait another 5 mins, and turn on, if this still doesnt work, contact the customer service line of the company who made your tv
Mar 17, 2012 | Sharp Televison & Video
The sound on my TV has suddenly stopped working
check all wires are firmly in place, especially the scart lead, and just give them a little push to make sure, if that doesnt work, try unplugging your tv from the mains and wait 5 mins, plug it back in, wait another 5 mins, and turn on, if that doesnt work, contact the company's customer service line.
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
Mar 21, 2011 | Element Electronics FLX3210 32 in. LCD TV
TV turns on/off automatically at 1-2 mins intervals.
Replace the power supply, PN: BN44-00206A
It's easy to locate, but requires adjustments once it is installed. Panel voltages must be adjusted according the the specifications of the TV. There is a sticker on the back of the plasma panel which provides each voltage setting. You can reference this sticker to make the proper adjustment. Using a DMM, connected between chassis ground and the panel voltage you are adjusting, turn the adjustments on the power supply very slowly, until you are measuring the specified voltage within 0.5v. I hope this helps and good luck.
Mar 15, 2010 | Samsung PN50A400 50 in. HDTV Plasma TV
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
My tv will work for like 5 min then it shuts off
Sound like you have a overheating problem. Your capacitors might have reached their end of life thus making them overheat quickly. Try to check if there is a fan inside your TV. If there is a fan, try to clean it see if that helps.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | RCA TruFlat 27F520T 27" TV
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Tv turnitself off and on at will
This sounds like a power supply problem possibly a bad capacitor
Jun 19, 2006 | Quasar SP-2023D 20" TV
Philips 43PP9202 43" Rear Projection Television Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
