Question about Minolta EP4000/5000 CS/PRO Copier
Smudge on the paper
I have a Minolta EP4000/5000 CS/PRO Copier , i see a smudge on every copy, i want to have manual of this machine so that i may learn its basic operation and abut troublshooting
  • bagumacharle Mar 01, 2009
    I have a minolta ep4000/5000 cs/pro copier. But have no its hand manual for services or troubleshooting. Could you please help and send me one?
    thank you
    kind regards
  • Minolta Expert
  • 1,326 Answers
When you say smudges, do you mean toner spot or blobs of toner on you pages? If you get random blobs of toner... You need to take out the drum unit & remove the primary charge unit & remove the drum & vac. out a small little grove that seats right below the developer mag roller... It is most likely filled with toner and is dropping on to you paper as copies are being made. Good Luck
Posted on Feb 27, 2009
MINOLTA CSPRO EP1083 PHOTOCOPIER NOT WORKING DISPLAYS "COF 30 " AND STOPS COPYING
Open the paper drawer and switch the green button which is located towards the back of the paper drawer on your left. My copier does this everytime I add paper.
Oct 11, 2010 | Minolta EP1083 CS/PRO Copier
Minolta cs Pro- Works but print black copy?
Please clean the mirror unit,the trasfer and separator coronas,and perform F5 AIDC control.
May 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
Power is on, but blades dont move
What do mean about blades not moving. The machine is a legacy minolta machine. The paper draw rollers mite need replacement. does the paper leave the draw?
Apr 10, 2010 | Minolta EP1030/1030F CS/PRO Copier
I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Mar 16, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have a Minolta EP 1083 the copies that it gives smudge
If fuser rollers are getting hot - you either lack pressure between upper and lower rollers Restart; remove/dump old developer - instal correct compatible starter reinstal imaging unit remove toner ctg. key in stop 0 stop 1 tec rep run F-8 mode runs apx. 2 min. exit svc mode If whats not fusing is gritty(starter) - other issues
Jan 19, 2010 | Minolta EP1083 CS/PRO Copier
Is the Minolta cs pro 5000 strickly a copy machine or is it a printer too?
Im pretty sure this is an analog machine. One way to test this for sure is to make multiple copies of one original. If the light scans the paper each time, then it is a analog machine and can't be hooked up to a computer. Digital machines generally scan the document only once then print many.
Dec 04, 2008 | Minolta EP4000/5000 CS/PRO Copier
I thinking of buying one of these machines
The Minolta EP-5000 is a analog copier. That means that it can not be connected to a computer to print to, it is just a 50 a minute copier.. It is to old to be connected, it came out around 1996 or so..... It is naot a bad copier, it is one of there old work horse... It is a up-dated version of the EP-3050 & 4050.
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Oct 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Paper jams minolta 1080 cspro copier
Can you explain where exactly the paper jams, just check any obstruction in the paper path, or clean all the clutches/ sensors for registration and transport
May 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
172 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
