Question about Philips 9P6031C 60" Rear Projection Television
My 55" Phillips Rear Projection tv has perfect sound but no picture at all.
    Genius:
  • 1,139 Answers
Hello sdbeynon,
This usually denotes a problem in the high voltage section either trippler or the IHVT. Since this section of the Tv has hazardous voltages I would suggest that you get a TV repair technician to give you an estimate on the cost of repair.
Judging by what you described it sounds like the trippler may have a problem. Have the technician check that first, or if you have a high voltage probe here is the procedure:
1) Remove the rear of the Tv set
2) clip the ground lead of the HV probe to ground.
3) using the tip of the probe touch the input of the trippler block you should have a voltage of 20Kv - 30Kv
4) touch the individual outputs of the trippler block they should each read 20Kv to 30Kv.
If the input is not present the IHVT or the trippler is bad, however if the 20Kv to 30Kv is present on the input but not the output the trippler itself is the problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 18, 2009
Our Phillips HD projection tv has lost a picture. It started by blacking out once in a while but now the picture is constantly rolling. The screen is distorted and it's impossible to even recognize what is...
Cloudy,distorted pictures.The tv have R,B,G CRT tubes gun coolant probblem.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced.
Sep 11, 2010 | Philips 55PW9363 55" Rear Projection...
I have static in the picture. Looks like a swarm of bugs moving around the screen. It is a phillips rear projection
sounds like poor tuner singnal solution mak sure u have gooddddddd connection with ant or cable make sure ur tv is on right station exe 2 3 4 this should resolved yur problem if not if you have bacis electronis skills i instruct u on repair
Jul 25, 2009 | Philips 55PW9363 55" Rear Projection...
Aspect ratio and tv type
The phillips 9P5544c isnt a HD tv so you will only have 4.3 formatt available
Jun 20, 2009 | Philips 9P5544C 55" Rear Projection...
No picture or sound
Contact us at www.TvRepairKits.com. We are working on solving this problem as we speak.
Nov 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
PHILLIPS 559401 REAR PROJECTION TV
ok the problem u have is that u need to have a scope and a volt meter to test the circuits what i would do is check and see if u have a 130 v on the horiza output transistor first. but if u dont have any meters there is nothing u can do to fix the problem. and just rember that phillips allwas wonts u to buy the board that is y it is not cheep to repair a magnavox or phillips sometimes u can buy another tv lot cheaper. i hope this help some what marty.
Oct 13, 2008 | Philips 55PP9401 55" Rear Projection...
No picture
voltage tripler...and deflection bd........
Jan 13, 2008 | Philips 55PW9363 55" Rear Projection...
Phillips 512pp9303h17
could be short in convergence board, also could be vertical output. Most of these sets are convergence amps need replacement.
Dec 06, 2007 | Philips 55PP9363 55" Rear Projection...
Philips 9P6031C 60" Rear Projection Television Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
