Question about Garmin StreetPilot C330 GPS Receiver
Power dors not transfer thru the connection between the wire and unit on my c330 , it appears that a little gold wire has broken in the rubber mount.
  • 31 Answers
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Posted on Mar 30, 2009
Power windows don't work on all 4 doors and power lock doesn't work on the driver door. 2004 jeep grand cherokee
On the driver side, the window/door lock module has the power lead either pulling away from the connection or has broke entirely. Another common cause is the wire harness between the door jam, this is the area that has a rubber boot covering the wires and from opening and closing the door, it creates a broken or loose connection over time. Open the driver side door, grab the rubber boot that the wires run thru, and move it around. Some times this will help create the connection and restore the power. If not, the door panel will need to be removed to inspect the wire connections.
Dec 31, 2010 | 2004 Jeep Grand Cherokee
My honda wont start i replaced the starter on it and i checked all fluids and my main fuze box. Nothing looks burnt or out of place, the small wire that has a rubber boot that connects on to the starter is...
Hi ,
That small wire with the rubber boot that appears broken most likely is the problem.
That wire, is the wire from your ignition switch that activates the starter solenoid which in turn activates the starter.
I know it is tight around there but by peeling the insulation back from the broken little wire, the wire can be spliced back together.
Parts houses have **** crimp connectors to do the job. The repair part is less than 50 cents..
Wayne
Dec 19, 2010 | 1997 Honda Civic
I have a garmin street pilot 330c, when i turn it on i have a system error with the hard drive has
I have a garmin c330 that works well except the little connection for power broke when it fell from the window. The unit still works well on battery. I need the small connector under the unit to operate with my DC cord. Does anyone have one they do not want or does anyone want the c330 for a small price. I purchased another newer Garmin
Mike
Jul 25, 2010 | Garmin StreetPilot C330 GPS Receiver
Power plug broken, missing parts to get power
Eloise, did you ever find a solution to this problem with yur Garmin? I have the same problem and don't want to spend $40 for an entire mount. Let me know, you can email me at JeffWang3@gmail.com. Thanks!
Mar 28, 2010 | Garmin StreetPilot C330 GPS Receiver
Kitchen circut was accidently turned off. Now whirlpool gold disher will not work(unit was not running and the door was not closed all the way when circuit was turned off, All circuit breakers are on)...
You can put the unit into diagnostics (press the following keys in order within 6 seconds HEATED DRY, NORMAL, HEATED DRY, NORMAL all the lights will come on and it will start a diag cycle) and see if it recovers. If not, you are looking at a electronic control, and yes you CAN change the part yourself.
Mar 08, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Need battery for street pilot c330
THis battery will work in your C330 Garmin. I have had it in my unit for 3 years now without any issues.
http://www.etronicspal.com/132805.html
Just open the unit and splice the wires, and use some electrical tape. Good as new.
Jul 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Power to same, but not turning on, can't locate so-called "reset" button on bottom????
Looking at the docking area note the gold connection terminals and which end the round coaxial connector is at. You should also be able to see the green circuit board that the terminals are mounted to. Then next to that you'll see a section of the plastic casing that has a little rubber piece in it. At the end of that part of the case opposite the coaxial connector mentioned earlier you should see a small notch in the plastic. That is the reset button. With the unit on use a regular size paper clip and gently press it in and you unit should reboot.
May 26, 2009 | Tomtom GO 910
Garmin c330 will not power up
Assuming that your power source is known to be live (ignition switch on?), the first suspect is the power cord, including the fuse inside the big plug. On the tip of the plug, the silver nut should be tight but the plunger in the center should move when you press it. To check the fuse, unscrew the silver nut. Take out the fuse, which looks like a glass tube with a wire inside - the wire should be unbroken. Better yet, check the fuse with an ohmeter. At the other end of the cord, disconnect and re-seat the connections to make sure they are secure. If using the suction cup mount, you'll need to unclip the unit from the mount to do this. Another possibility is a bad battery inside the unit. My C330 kept going off and on due to a bad plug/fuse assembly. When I switched to a friction mount, it came with a new power cord and the problem went away.
Jul 26, 2008 | Garmin GPS
Garmin c330
pins on the mount are broken
Mar 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Data transfer from Steetpilot c330 to a nuvi 200
Unfortunately, the only way to transfer these addresses is one by one by hand. There is no way to connect the units and transfer them, or connect the unit to the computer and transfer the Recent Selections to it, and back to the new unit.
Dec 23, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
143 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
