Question about Symphonic ST419E TV
Every fuse blows that I put in
The fuse blew then I went out and got a new fuse.But when I put it in and plugged it in that fuse blew too.But I put the right fuse in.Then I tryed it 3 more times with 3 new fuses.
  • 55 Answers
Okay, it's not the fuse. It drawing to much current and that's the trouble. You better call the repairman.
Posted on Feb 18, 2009
Blew a fuse now amp wont power up
It must go to a repair shop. There's always a reason that a fuse blows.
Jan 28, 2014 | Marshall Mg100dfx 100-Watt Combo Guitar...
My aquabot keeps blowing fuses in or out of water
may be waterlogged. internal seal failed and its shorting out..
Aug 06, 2012 | Pool & Spa
Having taken the xmas decorations down i moved the telly stand so that we could clean around the back unfortunately my wife accidently knocked the telly and everything went off it even blew the main fuse...
Blowing your fuse means you have a short circuit my friend. Even you replaced the fuse again and again it will do the same thing unless you isolated the problem. Blewing your fuse happened because it is a guard to avoid further damaged to you and your property. If you haven't a fuse fire will occured in the blink of an eye (thanks for the fuse) This is quit technical so I've advice you to look for a qualified electrician to isolate the cause of short circuit.
Jan 04, 2011 | Televison & Video
It went off on its on and won't come back on. It just popped off while I was watching it.
It likely blew a fuse. However, TVs rarely blow a fuse for no reason. I recommend getting it fixed. You can try a new fuse of the same size, but if it blows, please get it repaired. DO NOT put a larger fuse in - fire hazard. The fuse maybe solder in.
Apr 21, 2010 | Televison & Video
Fuse keep blowing
Means that item the fuse is protecting is bad.Fusing unit is a good start replace it
Apr 01, 2010 | Office Equipment & Supplies
Tv problem with a fuse
Your degausing thermistor is bad and needs to be replaced. The part number is D4DDF1R50001
Once that is replaced put a new fuse in put the set back together and you should be good to go. You will need to replace the fuse with the correct size and its part number is
XBA2A00101F
Sep 10, 2009 | Panasonic CT-36SX12 36" TV
Flat panel tv blows fuses
next to the fuse that blows is 4 large black diodes2.gif.one of those is common to short out. the bad one would give you areading of zero ohms when checked with a meter. or just replace all 4.most likely its location D603. hope this helps
Nov 10, 2008 | Sylvania 6626LCT 26 in. LCD Television
Car Amp keeps blowing fuses
The reason why fuses blow is that the current is too much. Is the fuse rating according to the specs ? If yes then ... One or more output power transistor (or audio power IC) may be shorted. have it checked before replacing another fuse as this might cause more damage.
May 22, 2007 | Profile CL1200 Car Audio Amplifier
Symphonic ST419E TV Logo
127 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
